2" spring lift - Max Tire size??? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 09-10-2010, 08:08 AM Thread Starter
What is the max tire size I can install on my 2008 JK rubicon if I put a 2" spring lift on?
kyahkyah is offline
post #2 of 6 Old 09-10-2010, 10:34 AM
leman's Avatar
im running rustys 2" with 35x1250 hankooks. i get slight rubbing when flexing. im probably gonna cut my fenders soon. right now i just take them off when im hitting the trails.
2008 steel blue sahara
with some doo-dads
leman is offline
post #3 of 6 Old 09-10-2010, 10:40 AM
leman's Avatar
and that last pic was my first trip with the new tires when i found out they rubbed
with some doo-dads
leman is offline
post #4 of 6 Old 09-10-2010, 11:13 AM
Yes you can run 35in tires with a 2in lift, and they say you can fit 37in tires with tube fenders..
later
jmd
jmd4x4 is offline
post #5 of 6 Old 09-10-2010, 11:15 AM
ABSOLUTE maximum would be 37s. you would have to run extended bumpstops, trim your fenders, pinch seams, and adjust your steering stops. wouldnt have much flex off road assuming you wheel it
BBirish is offline
post #6 of 6 Old 09-10-2010, 06:45 PM
wsoffroad's Avatar
Feedback: 12 reviews
I know with the Rock Krawler 2.5 Stock Mod kit you can run 37's with flat fenders and proper bumpstops. With a Rough Country I would say 35's are the max. Alot also depends on the tires your gonna run some 37's actually measure out to 35"-36"
Hope this helps.
Rock Krawler, Poison Spyder, Rigid Industries, Currie and more.
OR CALL 813.361.0869
wsoffroad is offline
