There are no dumb questions?? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 09-09-2010, 05:33 PM Thread Starter
ACE
ACE's Avatar
I'm looking into 35's....
Is there any difference between 315/75 R# and 35/12.5/R# ?
I've heard some tires are "35" but are really 34.5.... idk if that has anything to do with it... Edumecate me
also, Looking into these
R16
http://www.onlinetires.com/products/...++n%252Fa.html
or
http://www.onlinetires.com/products/...t+n%252Fa.html
U.S. Air Force
"Sitting on ours, Saving yours."
2009 Unlimited X Stone White
2.5" TF Lift
...Mods As money flows...
1.5" Wheel Spacers
35" BFG MK2
ACE is offline
post #2 of 5 Old 09-09-2010, 05:43 PM
StubEXrube's Avatar
After about 10,000 miles, my 35" KM2's measured just under 34". KM2's are about an inch off on all sizes. I've heard and seen good things from the Toyo's, but they are a little heavy, so may take a little more weight to balance- idk.
The KM2's do perform very well and exhibit pretty good on road manners- although my 35's were louder than my 37" MTR's.
StubEXrube is offline
post #3 of 5 Old 09-09-2010, 05:51 PM
KevinJBurt's Avatar
Send a message via Yahoo to KevinJBurt
You need the rim size in that equation it makes a difference...Go to the calculator at discounttire.com and it will show you all the equations.
Always forward never straight sometimes upside-down!
KevinJBurt is offline
post #4 of 5 Old 09-09-2010, 05:58 PM
Ron R's Avatar
My 35" Mickey Thompson Baja MTZ's measure exactly 33" from the ground to the top of the tread. I'm not sure how many miles are on them, tread is probably half of what it once was. So their "35" is really only 34-ish anyway, minus the tread and bulge from being under-inflated puts me at 33.
Keep this in mind when you do get new tires - you need to recalibrate your speedo for the MEASURED size, with the amount of air pressure you want in them, not the manufacturer's stated size. Measure from the ground. When I programmed the speedo at 34.whatever it was off, when I reprogrammed it at 33" it was spot-on accurate with the GPS.
Ron R is offline
post #5 of 5 Old 09-09-2010, 07:00 PM Thread Starter
ACE
ACE's Avatar
I see, with KM2s
Overall Diameter:
315/75/r16 ...34.6"
vs
315/75/r17 ...35.6"
....Sooo I'm going 17"s now...I guess there are No dumb questions lol, learned something new today
U.S. Air Force
2.5" TF Lift
1.5" Wheel Spacers
35" BFG MK2
ACE is offline
