pa lift laws? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 23 Old 09-09-2010, 02:02 PM Thread Starter
jk_ed's Avatar
pa lift laws?
After a little harassment from one of our local boys in blue I have done some research but have seen many different answers to what the law actually states in Pa. The cop said he wouldn't write me a ticket because he wasn't sure what the law actually sez.he also assured me that there were 2 officers that had been to class to specifically learn the law for modified vehicles and they would be more than happy to write me a ticket. So does anyone know if its bumper or frame height the use? Both my front and rear bumper measure 28" to the bottom of the bumper and my frame height is 23 & 1/4.
07 black unlimited. 5.5" rock krawler x factor long arm. Pro comp soft 8s, 37" nitto mud grapplers. Kilby front winch bumper. Warn xd9000i. OrFab rear bumper. Much more to come in the near future.
jk_ed is offline
post #2 of 23 Old 09-09-2010, 02:49 PM
bonecollector's Avatar
Pm Jeffs jk he does inspections in Pa, he might have a clue,hes a good guy.
bonecollector is offline
post #3 of 23 Old 09-09-2010, 03:09 PM Thread Starter
jk_ed's Avatar
Thanks, I will give him a holler
jk_ed is offline
post #4 of 23 Old 09-09-2010, 04:24 PM
BenFoo's Avatar
It it should be the lowest part of the bumper.
BenFoo is offline
post #5 of 23 Old 09-09-2010, 04:29 PM
You might find something useful here:
hxxp://bronco.zenseeker.net/LiftLaws.htm
GreenJK is offline
post #6 of 23 Old 09-09-2010, 04:32 PM
BeerMonkeY's Avatar
bumper. i got pulled for it on my yj, bu ti dont remember the height allowed. the problem is that in pa the bumper height goes by vehicle type (truck can be higher than cars) and a jeep is registered as a station wagon so its considered a car. although i did get a fix it ticket for it, when i took the jeep to the police station the cop that was there said it was a stupid ticket and the cop that gave it to me was a asshole. but my jeep did look awesome with the 18's off my suburban and rubber bands for tires .
'92 YJ
'13 WK2
BeerMonkeY is offline
post #7 of 23 Old 09-09-2010, 04:32 PM
BenFoo's Avatar
http://www.dmv.state.pa.us/pdotforms.../section_e.pdf
175.78. CHASSIS.
(e) Bumpers
(6) Some part of horizontal bumper bar on
multipurpose passenger vehicles and
light trucks shall fall within 16-30 inches
above ground level.
Note: The Department delayed the
effective date of the repeal of
§175.78(e)(6) at 29 Pa. B. 2460 (May
8, 1999).
That is the current law as far as I know. The one that was delayed is a bit different.
http://www.dmv.state.pa.us/pdotforms...5/appendix.pdf
-=DELAYED=-
5) Bumper Height - Bumper height shall
be as follows:
(i) Some part of the main horizontal
bumper bar, exclusive of any bumper
guards, on passenger vehicles and
light trucks shall fall within 16 inches
above ground level and may not
exceed the following limits:
Vehicle Class Maximum Height
Front Bumper Rear Bumper
(or Frame if (or Frame if
any of the any of the
conditions in conditions in
subparagraph subparagraph
(ii) apply) (ii) apply)
Passenger Cars .......................... 22 inches ........ 22 inches
Trucks and multipurpose
passenger vehicles:
5,000 lbs. or less GVWR ........... 24 inches ........ 26 inches
5,001 lbs. - 7,000 lbs. GVWR .... 27 inches ........ 29 inches
7,001 lbs. - 9,000 lbs. GVWR .... 28 inches ........ 30 inches
9,001 lbs. - 11,000 lbs. GVWR.. 30 inches ........ 30 inches
(ii) The front and rear height measure–
ments shall be made to the bottom
edge of the foremost portion of the
frame rail, or to the original mounting
brackets, whichever is lower, if one of
the following apply:
(A) The bumper height, relative to the
frame rail, has been altered.
(B) The vehicle was not originally
equipped with a front or rear bumper
BenFoo is offline
post #8 of 23 Old 09-09-2010, 05:32 PM Thread Starter
jk_ed's Avatar
Thanks benfoo. I guess im not even close to legal. Maybe I will order a set of 3 1/2" springs to get it down a little and hope it doesn't draw quite as much attention. Besides the 37's look small with the 5 1/2"
jk_ed is offline
post #9 of 23 Old 09-09-2010, 05:45 PM
BenFoo's Avatar
so the lowest part of your bumper is not between 16-30"?
BenFoo is offline
post #10 of 23 Old 09-09-2010, 05:48 PM
BenFoo's Avatar
k, i just measured mine.... with a 4" TF (which is more like 5") and 38s my front is about 24" to the crash bar and the rear is 27".
BenFoo is offline
post #11 of 23 Old 09-09-2010, 06:00 PM Thread Starter
jk_ed's Avatar
Ok I think I get it now. The second part is what was repealed? And the 1st part you posted is what's actually current? Im at 28" exactly at the bottom of the rear bumper and around 28 & 1/2 on the front. I netted way over 5.5" from my lift( mine sits a good inch higher than my buddies with the same tires and the 6.5" bds. So I may still drop down to the 3.5" springs just to get it down a little.
jk_ed is offline
post #12 of 23 Old 09-09-2010, 06:21 PM
BenFoo's Avatar
I try not to run more lift than I need for two purposes. 1) COG 2) Popo
Althought you're technically still legal, in areas where cops have nothing else to do, you'll prob get hasseled due to being close.......
BenFoo is offline
post #13 of 23 Old 09-09-2010, 06:42 PM Thread Starter
jk_ed's Avatar
I agree with that. Like I said, I netted around 7- 7.5" out of the lift. I hoped it would settle some but that hasn't happened and its been 4 months. So I will be looking into RK's 3.5" springs. Or maybe someone's else's 3" or 4". Thanks for the good info, much appreciated
jk_ed is offline
post #14 of 23 Old 09-09-2010, 07:10 PM Thread Starter
jk_ed's Avatar
Just got confirmation from an inspection tec that 30" is indeed the magic number in pa. Thanks to benfoo for digging up the info in the 1st place and to jeffsjk for confirming it. Now if we could just get back to having some tire sticking out I would be golden.
jk_ed is offline
post #15 of 23 Old 09-09-2010, 07:36 PM
yeap, thats right . 30 inch . tell the guyz in blue to kiss your ass and read the pa laws . dont drop the jeep your legal.
jeffs jk is offline
post #16 of 23 Old 09-09-2010, 07:38 PM
know the tires cant not be 3inches out of the flares.
jeffs jk is offline
post #17 of 23 Old 09-09-2010, 07:40 PM
BenFoo's Avatar
thats the reason i held onto my 35s......for inspection and any 'fix it' tickets.
BenFoo is offline
post #18 of 23 Old 09-09-2010, 07:47 PM Thread Starter
jk_ed's Avatar
Wish I had a spare set of 35's for that purpose. I do have my oe wheels and tires. It would be sweet looking with the 245/70/16's
jk_ed is offline
post #19 of 23 Old 09-09-2010, 07:52 PM
BenFoo's Avatar
silly or not.....its legal =]
BenFoo is offline
post #20 of 23 Old 09-10-2010, 06:37 PM
if your near philly just pm me , if you need insp.
jeffs jk is offline
post #21 of 23 Old 09-11-2010, 02:38 PM
voodoojk's Avatar
from what i been pulled over for and told is no tread can exists beyond the flare. Do the ol quarter on the fender drop tricks and if it hits actual tread (not sidewall) you are illegal. And i have had cops do it in the past.
2007 Wrangler
Rescue Green
3.5" AEV Lift
37" GoodYear MTR
Pro Comp 7089's
Tom Woods Shafts F&R
OR Fab Tire Carrier
Shaffer Stinger
Bulldog Winch
Buschwacker Flat Flares
Poly Tie Rod
JKS Disco
voodoojk is offline
post #22 of 23 Old 09-11-2010, 02:47 PM
BenFoo's Avatar
Legally speaking, yes the tread must be covered. However, ive yet to be pulled over for my tires sticking out <knock on wood>. Ive had police follow me, rolling beside me and generally keeping an eye on me. But, im of the notion that if you dont do anything retarded like a moving violation and/or cause an accident the really dont care or have the time too.
Inspection is a different animal. Thats why I held onto my 35s, for inspection. Even if someone were to pass my jeep, I really dont want to put them in that tough place as if they DO pass it with current wheel/tires on then it could come back to bite them in the ass. ie they loose their inspection liscense. Just saying....
BenFoo is offline
post #23 of 23 Old 09-11-2010, 07:35 PM Thread Starter
jk_ed's Avatar
Thanks Jeff's jk. Unfortunately im on the other end of the state otherwise I would take you up on that offer. I guess I will have to add the wide xenons to winter project list. With no spacers they should just cover the tires.
jk_ed is offline
