New Gears installed and... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 09-08-2010, 10:36 PM Thread Starter
Joneszj's Avatar
I was just wondering if any of this is normal...
I have diff fluid all over my drivers side front, on the frame, lower control arm, etc. I may have overfilled the diff after throwing on my new covers, and I checked them all over for leaks. The silicone is sealed up nice. The bottom of the diff has some fluid on it, and I also noticed that fluid could possibly be escaping from where the driveshaft connects. Is this normal? Would overfilling it make it spew out like this? I can't tell if it's correct or if O made some sort of mistake and there is an actual leak on the back of the pumpkin where the DS attaches. Any opinions?
And, my cruise control isn't working. Broke the ABS sensor on the front drivers side doing the install and I have to get it fixed. Maybe this is a dumb question, maybe not, I have no idea what all the computers do in the JK...could the missing ABS sensor prevent the cruise control from working? Any other ideas what could have happened for the cruise control to no longer work?
1972 Commando on Tons & 40s
Joneszj is offline
post #2 of 16 Old 09-08-2010, 10:45 PM
BenFoo's Avatar
You prob did overfill the diffs sounds about right for where it would overflow. Keep an eye on it and make sure it stops. Wipe the axle parts off if you can. Dont worry about the stuff on the left/driver side.
BenFoo is offline
post #3 of 16 Old 09-08-2010, 10:46 PM
BenFoo's Avatar
I believe the wheel speed sensors are used for the cruise control. Not 100% sure though.
BenFoo is offline
post #4 of 16 Old 09-08-2010, 10:48 PM
BenFoo's Avatar
Did you replace the driveshafts at the same time?
BenFoo is offline
post #5 of 16 Old 09-09-2010, 04:03 AM
Idriveoverstuff's Avatar
A good way to tell where and how fast the oil is leaking is to spray it all off with brake cleaner and then watch for it to come back.
2009 X 2-door 6-speed
budget boost, bilsteins, discos, 35's, 4.88's, and more issues than TV Guide
Idriveoverstuff is offline
post #6 of 16 Old 09-09-2010, 06:01 AM
2k2wranglerx's Avatar
Diff fluid on the frame means its puking it outa the breather. If you have g2 covers drive tiill they warm up then tighten the drain plug, and it sounds like your pinion seal is leaking (where driveshaft connects to yoke). Our local auto parts store had a listing for the pinion seal but they all had the wrong one, had to get it from the dealer for 30 bucks.
Good luck
2k2wranglerx is offline
post #7 of 16 Old 09-09-2010, 07:03 AM
is the fill plug on the G2 covers at OEM location or is wayyy up like the SOLID covers??
no jeep here...
Racer83l is offline
post #8 of 16 Old 09-09-2010, 07:23 AM Thread Starter
Joneszj's Avatar
Nope, still have the stock driveshafts. And I think it may have been the breather tubes. I have the Solid covers so I bet I overfilled it, I used about 2 and 1/2 to 2 and 3/4 quarts to fill it.
I wiped everything down so I will check after driving it today whether there is anymore leakage. The RTV sealed up fine, so I think the only place it could possibly be leaking is where the DS goes into the pumpkin...but everything looks tight. Hopefully it was just the breather, but if its the pinion seal i can probably get it fixed up if needed. Is that a dealer part I'll need to order or can I get it pretty much anywhere?
Joneszj is offline
post #9 of 16 Old 09-09-2010, 07:31 AM
pinion seal = pain in the ass.. new crush sleeve, pinion nut, pulling driveshaft, removing carrier etc.
HOPEFULLY your just overfilled, and the wind was blowing it all over the place...
I hate how easy it is/hard to properly fill a diff when you have the fill plug so darn high on the cover..
What I usually do is make a dipstick with a piece of paper and fill it just above the top of the 2 bolts at the bottom of the axle tubes. (if that makes any sense..) Currently I am on the hunt for aftermarket covers with OEM fill height plugs.
no jeep here...
Racer83l is offline
post #10 of 16 Old 09-09-2010, 10:17 AM
BenFoo's Avatar
for my D44 axles...
Front ~ 1.5QT
Rear ~2.5QT
So thats an even 4QT basic for both...
BenFoo is offline
post #11 of 16 Old 09-09-2010, 10:49 AM
you don't need a new crush sleeve for a new pinion seal. pull the yoke, pull the seal, reinstall, and tighten down the pinion nut real tight (although i do agree that it's not a bad idea to replace the pinion nut).
just don't go overboard and crush the crush sleeve more. I usually impact it till it pretty much stops, not so much that i'm sitting there hammering on it, but you zip it down till it stops, although last time i said that people lost their minds.
you can use a wrench too and go by feel. bottom line though is even if you took it to a dealer they're not going to put a new crush sleeve in.
post #12 of 16 Old 09-09-2010, 10:50 AM
for my D44 axles...
Front ~ 1.5QT
Rear ~2.5QT
for his front 30 i think it's 1.3, rear should be teh same
i buy 80/90 in a gallon jug and use a pump to pump it in.
post #13 of 16 Old 09-09-2010, 11:42 AM
VKS Fab
JK Vick's Avatar
X2.
Handmade One At A Time
GIVE US A CALL 559-392-3145
JK Vick is offline
post #14 of 16 Old 09-09-2010, 01:39 PM Thread Starter
Joneszj's Avatar
I'm guessing its overfilled if I was only supposed to put in about 1.5 qts. Pretty sure it leaked out about a qt over the course of yesterday and today driving. And it only sprays out onto the drivers side. I'm going to a shop tomorrow to get it looked at.
Joneszj is offline
post #15 of 16 Old 09-09-2010, 02:11 PM
StubEXrube's Avatar
Even when filled to the correct level- the front will still tend to spew out the breather- more so at highway speeds. Many have this issue including mine. I believe that it has to do with the reverse cut gears in the front diff- but some disagree- whatever.
Best thing is to keep an eye on it- check your fluid level from time to time to make sure it is not too low. I would get the ABS sensor taken care of, but I would not personally spend the time/ money to have them look at the fluid discharge. It's definitely coming from the breather tube, and there is not a single thing that the dealership can do (or will do successfully) to remedy the issue.
StubEXrube is offline
post #16 of 16 Old 09-09-2010, 04:51 PM
jjbooth's Avatar
Overfill
Just did my gears and have the same issue.........overfill in the front 30. Worried at first but after checking it I found out it is spewing from the top of the breather tube. I have just about 200 miles to go before I reach my 500 breakin, so I'm just waiting until then to correct the problem when I change the oil.
JJ
jjbooth is offline
