Whose control arms do not have to be removed for adjustment? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 19 Old 09-08-2010, 08:43 AM Thread Starter
jsherm01's Avatar
I'm trying to decide whose adjustable control arms to buy. I don't think I want to remove the mounting bolts for each freaking adjustment...
So whose do not have to be removed to adjust them?
Clayton?
TeraFlex?
PolyPerformance?
Others...?
Thanks!
jsherm01 is offline
post #2 of 19 Old 09-08-2010, 08:53 AM
NorthGAX's Avatar
Send a message via AIM to NorthGAX Send a message via Yahoo to NorthGAX
I know that Poly Performance arms do not need to be removed.
Love you brother and you will always be my hero!
NorthGAX is offline
post #3 of 19 Old 09-08-2010, 09:23 AM
Poly or Icon are the only 2
post #4 of 19 Old 09-08-2010, 09:28 AM
RK, is one better than the other that you guys chose not to make yours adjustable on the rig?
no jeep here...
Racer83l is offline
post #5 of 19 Old 09-08-2010, 10:38 AM
Price, the Poly arms are a little more money than most because the added parts for the double adjuster
GOAT1 is offline
post #6 of 19 Old 09-08-2010, 10:45 AM
venom's Avatar
its niiiiiice to be able to adjust my poly arms with the rig on the ground!
Originally Posted by My Wife
venom is offline
post #7 of 19 Old 09-08-2010, 12:26 PM
TrailDuty.com
PhilD's Avatar
X10 I don't do it that often, but often enough to really appreciate how easy they are to adjust on the vehicle.
PhilD is offline
post #8 of 19 Old 09-08-2010, 03:11 PM
2k2wranglerx's Avatar
you shouldn't really need to adjust them unless you're changing the height of the vehicle.
RK's would be tough since they have that high clearance bend to them...
2k2wranglerx is offline
post #9 of 19 Old 09-08-2010, 04:57 PM
Mall Krawler's Avatar
Why are you adjusting your arms so much ?
Mall Krawler is offline
post #10 of 19 Old 09-08-2010, 06:22 PM
TrailDuty.com
PhilD's Avatar
Changes in lift height, adjusting front pinion/caster angle, adding/losing weight, moving axle forward/backward, etc, there are many reasons.
PhilD is offline
post #11 of 19 Old 09-09-2010, 08:34 AM
ryanblack321's Avatar
I bought the AEV Front control arm brackets instead of adj. control arms.
They not only got my caster near perfect but my steering and overall handling became much better. The brackets are only 100 bucks and are very beefy.... Much cheaper than adj. control arms.
I spoke with Northridge about them and he said they are a great upgrade for the money and 3 times less expensive than 1 set of adj. control arms
i am very pelased with these...
2011 Jeep JK Unlimited
Blessed is the man who perseveres under trial, because when he has stood the test, he will receive the crown of life that God has promised to those who love him. James 1:12
ryanblack321 is offline
post #12 of 19 Old 09-09-2010, 08:45 AM
RIP Brad
abendx's Avatar
First time seeing these.
Looks like a poor solution... the stock mounts and arms are vulnerable enough, dropping them even lower.... ouch!
abendx is offline
post #13 of 19 Old 09-09-2010, 09:18 AM
We do not put double adjusters in our arms because we believe in the KISS principle. It is one more added thread section to possibly have an issue with, it adds even greater cantered loads to thread sections. If it happens to adjust while in the vehicle and the occupant does not know it, a control parameter of the vehicle is changing and the ones that are currently offered to not meet SAE standards for fastening.
We also do not feel people need to adjust their arms all that much unless major changes are occuring. Once the vehicle is set up properly, it should be good to go.
Those are merely our opinions on the subject matter.
Rock Krawler
post #14 of 19 Old 09-09-2010, 09:25 AM
PIG
PIG's Avatar
You said it, not me...
PIG is offline
post #15 of 19 Old 09-09-2010, 10:21 AM
sickchilly's Avatar
Send a message via AIM to sickchilly Send a message via Skype™ to sickchilly
Yeah, they hang a little lower. Yeah, you can bash them. I've done it on the Rubicon. Then again, I only have about 3.5" of lift and 35" tires on a 4-door. However, they held up just fine. They work as advertised and, for the money, they're a great value. I'll replace them with mid arms eventually, but in the meantime, they work just fine as skids while I have bigger things to worry about upgrading!
2007 Jeep Green Rubicon 4-door with various bits 'n pieces... broken in but not even finished!
sickchilly is offline
post #16 of 19 Old 09-09-2010, 10:53 AM
i put these on my wife's to help with castor and i was really suprised at what a difference it made, both in handling (fixing the castor and the flighty steering) as well as the ride (much better small bump compliance)
for 100 bucks they're good value.
if i was building a hard core rock crawler no way would i go near them. But for my wife's DD that'll get wheeled a few times a year, they're great.
AND IMHO light years better than cam bolts! (scary)
that's my .02
post #17 of 19 Old 09-09-2010, 01:09 PM
And how often are you really doing this I've had my set up for 2 seasons and a whole lot of trail rides and my arms have never needed to be re-adjusted.
post #18 of 19 Old 09-09-2010, 01:20 PM
TrailDuty.com
PhilD's Avatar
Several times a year so far.
Great for you, but clearly that isn't the same for everyone else.
PhilD is offline
post #19 of 19 Old 09-09-2010, 02:51 PM
bonecollector's Avatar
Mine, I run a poly long arm and love it
bonecollector is offline
