backspacing question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 09-07-2010, 07:31 PM Thread Starter
jvalason's Avatar
ordered a set of 17inch wheels with a 4.75 backspacing. Im going to run 40s and was told it would not rub...Looking around on here it seems 4.5 is the highest with 35s. Anyone with experience with this? 17x9 4.75 backspacing wheels and 40x13.5x17 tires. Lift is is RK long arm and D60 axles.
jvalason is offline
post #2 of 11 Old 09-07-2010, 07:53 PM
bfj aka tambil's Avatar
backspacing has everything to do with the WIDTH of the tire and not the diameter.
I run 4.5 BS with my 37" 12.5" wide tires. No issues.
Proud to be an American
Shamed of our government
Native Floridian = MUD
bfj aka tambil is offline
post #3 of 11 Old 09-07-2010, 08:01 PM Thread Starter
jvalason's Avatar
Ok so anyone know if 4.75 backspacing will work on a 13.5inch wide tire?
jvalason is offline
post #4 of 11 Old 09-07-2010, 08:22 PM
BenFoo's Avatar
If youre running full width D60 axles you should be fine. If youre running stock JK axles you will rub.
To run a 38x14.5R16 tire on a 16x10 wheel I had to go to a 3.5" B/S, but that is with the stock axles.
BenFoo is offline
post #5 of 11 Old 09-07-2010, 09:50 PM
Rerun's Avatar
Try using this wheel size calculator...
http://www.rimsntires.com/rt_specs.jsp
Plug in the numbers for your current rim and tire and compare them to your new rim and tire...
Rerun is offline
post #6 of 11 Old 09-07-2010, 10:28 PM
wsoffroad's Avatar
Feedback: 12 reviews
You will for sure rub at full turn on the lower control arms.
Rock Krawler, Poison Spyder, Rigid Industries, Currie and more.
OR CALL 813.361.0869
wsoffroad is offline
post #7 of 11 Old 09-08-2010, 12:35 PM
TrailDuty.com
PhilD's Avatar
A 9" wide rim is fine for a 13.5" wide tire, as to the back spacing, I run 17x10.5 rims with 4" backspacing and 40x13.5's and they rub hard on the frame with stock width axles. Wider axles will help a lot, but I'd still try and keep the Back spacing below 4".
PhilD is offline
post #8 of 11 Old 09-08-2010, 04:30 PM
jk_ed's Avatar
I run 37 13.5 on a 9" wheel & stock width axle and it rubs the lower arms at full lock.
07 black unlimited. 5.5" rock krawler x factor long arm. Pro comp soft 8s, 37" nitto mud grapplers. Kilby front winch bumper. Warn xd9000i. OrFab rear bumper. Much more to come in the near future.
jk_ed is offline
post #9 of 11 Old 09-09-2010, 10:39 AM
TrailDuty.com
PhilD's Avatar
Originally Posted by Desert Rat Off-Road View Post
If it rubs, you can run 1 1/2" wheel spacers.
I had to run 1.5" spacers back when I had 37's and rims with 4.75" BS on stock axles, otherwise they rubbed a lot.
PhilD is offline
post #10 of 11 Old 09-10-2010, 07:06 AM
fourplyn's Avatar
you said D60 axles...
if you have wider than stock axles..Then you might be fine..But you still might need a little back spacing. possibly 1/2".
Past jeep:
- 40" Pro Comp X-Terrain
fourplyn is offline
post #11 of 11 Old 09-10-2010, 11:21 AM
riverzendz's Avatar
There are some running 13.50 width on 4.5BS, most get rubbing issues. Some say a lot, some say not much.
I'm getting ready to mount a set myself on 4.5BS so we'll see.
riverzendz is offline
