Ford hp 44 swap. - JKowners.com : Jeep Wrangler JK Forum
 4Likes
  • 1 Post By Tweak
  • 2 Post By ChuckTheRipper
  • 1 Post By thedirtman
post #1 of 17 Old 05-28-2017, 06:49 AM Thread Starter
Ford hp 44 swap.
Okay so im swapping a 76 ford hp 44 into my jk. And im planning on running factory links for now. Whats the best way to mount the upper link mounts. Or a full truss with the mounts on it?
nick.mckannan is offline
post #2 of 17 Old 05-28-2017, 09:13 AM
https://www.ballisticfabrication.com...conversion-kit
Up to you but if you are going to use factory uppers then you need this style of mount. Lots of people make them. You will need some kind of bridge over the differential if your new axle does not have this style of mount.
post #3 of 17 Old 05-28-2017, 02:36 PM
Tweak's Avatar
Why a 44? It's an awful lot of work for an axle that barely compares to a JK 44.
Billet 2013 2 door
Dana 60 front, 14 Bolt rear, ARB's, 5.38's, 40" sticky Trepadors, 3 link front and rear, 14" Sway-a-Way coilovers, Tom Woods 1310 front, Adams 1350 rear, PSC Hydro assist
Tweak is offline
post #4 of 17 Old 05-28-2017, 05:02 PM Thread Starter
1/2 tubes are stronger. Running a full spool. Lockouts everyone likes there rig different
post #5 of 17 Old 05-28-2017, 05:24 PM
Tweak's Avatar
Yea man I'm all about doing new things, but there is a reason nobody swaps old dana 44's into their JK's. It's going to cost you just a little bit less and require just as much work as a dana 60.
What are you doing about the bolt pattern? What are you doing about the cast radius arm perches?
coilrod likes this.
Billet 2013 2 door
Tweak is offline
post #6 of 17 Old 05-28-2017, 05:29 PM Thread Starter
76 f250 isint cast going 5x5.5 was 8 lug along with my 9 inch rear. Axles were outa my old truck so ill have less than a 60 swap
post #7 of 17 Old 05-28-2017, 06:14 PM
a_ridder's Avatar
Heck I'm curious how this turns out. I see these d44 around quite a bit.
a_ridder is offline
post #8 of 17 Old 05-28-2017, 06:23 PM Thread Starter
Ill post pics along build.
post #9 of 17 Old 05-29-2017, 06:28 AM
76/77 F100/F150 did not have a hollow cast perch like the 78/79 F150/Bronco axles. 76/77 had 2 piece weld on wedges with a solid axle tube unlike the 78/79 that had a 1 piece cast wedge with 2 piece axle tubes.
-SLADE- is offline
post #10 of 17 Old 05-29-2017, 10:07 AM Thread Starter
Im not good enough on the internet to copy peoples text but dirtman i think im going to use these bushings with a custom bracket
post #11 of 17 Old 05-29-2017, 10:14 AM
RE does not have a good track record with joints. This is a good maintenance free joint and bracket that should last.
JK Front Duroflex Axle Bushing Kit
Without the bracket:https://www.metalcloak.com/2-OD-x-2-...ing-p/7302.htm
post #12 of 17 Old 05-29-2017, 10:16 AM Thread Starter
My buddy runs them on his ls buggy with 43s and swears by them. That link wont pull up on my slow phone.
post #13 of 17 Old 05-29-2017, 04:54 PM
ChuckTheRipper's Avatar
I was looking at those joints in 4wd's show room last week. One thing I noticed is the holes for the threaded washer are "through" rather than an indention such as rock krawler. That's a lot better of a design. I broke 2 of rock krawler's shitty ass sockets trying to rebuild a joint. Fuck rock krawler.
coilrod and ASSFROW like this.
ChuckTheRipper is offline
post #14 of 17 Old 05-29-2017, 05:16 PM
I would never recommend a rock krawler joint.
coilrod likes this.
post #15 of 17 Old 05-29-2017, 07:57 PM
Trust me, WE know. Lol.
post #16 of 17 Old 06-14-2017, 08:56 PM Thread Starter
Ill take some better pics this weekend.
post #17 of 17 Old 07-17-2017, 08:27 PM Thread Starter
Finally got the swap done.
