Traction control/anti skid/ESP issue after UD60 install - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 05-13-2017, 03:41 PM Thread Starter
Just finished installing UD60s in my 2014 JKU. Got everything aligned, steering wheel is straight, drives down the road straight, axles are centered but when I go around a sweeping right hand corner the anti skid/ESP or whatever its called kicks in and tries to "straighten me out". No lights on the dash, gear ratio is correct, tire size is correct, no codes when checked at OBDII port, I was very careful during the swap not to turn the wheel while the drag link was disconnected, had drag link zip tied to frame. Not sure what I'm missing here. Ideas?
stretch79 is offline
post #2 of 2 Old 05-13-2017, 04:11 PM
Tweak's Avatar
You may think your steering wheel is straight, but it may not be. It only takes a tiny bit of misalignment to make the computer go nuts.
Billet 2013 2 door
Dana 60 front, 14 Bolt rear, ARB's, 5.38's, 40" sticky Trepadors, 3 link front and rear, 14" Sway-a-Way coilovers, Tom Woods 1310 front, Adams 1350 rear, PSC Hydro assist
Tweak is offline
