Knurled Ball Joints - JKowners.com : Jeep Wrangler JK Forum
 7Likes
  • 1 Post By Dkjeep
  • 1 Post By Fklein6768
  • 1 Post By Rattler
  • 1 Post By Dkjeep
  • 1 Post By kjeeper10
  • 1 Post By christensent
  • 1 Post By Biginboca
post #1 of 13 Old 04-28-2017, 10:21 PM Thread Starter
1eviljk's Avatar
Knurled Ball Joints
Aside from Dynatrac and Teraflex are there any other manufactures that make Knurled ball joints. I currently have the Teraflex HD ball joints but 2 years ago when installing them I noticed they didn't clear the larger OEM axle shafts I used from a 2014 Rubi in my 2009. I ended up having to grind down the ball joint just a bit to get it to clear the top of the lower JOint which was a pain.
My driver side Lower ball joint was Destroyed from a violent axle shaft break and I need to replace it. I just ordered front and rear Carbon Chromoly axles and I can only imagine those front shafts wont clear the ball joint as well. My First mistake was going with knurled BJ's when just swapping out the factory ones. (still a newb) Now there's no going back. Any ideas?
Jeep is a 2009 sport with Rubicon Axles.
Thank you,
1eviljk is offline
post #2 of 13 Old 04-29-2017, 05:29 AM
Dkjeep's Avatar
I believe synergy is knurled.
Sent from my SM-G955U using Tapatalk
1eviljk likes this.
Dkjeep is offline
post #3 of 13 Old 04-29-2017, 05:37 AM
Fklein6768's Avatar
This and the rare parts can also be had knurled.
1eviljk likes this.
www.4x4s-pod.com
Fklein6768 is offline
post #4 of 13 Old 04-29-2017, 07:48 AM
I just went from synergy ball joints (knurled) to Rare Parts (non-knurled); the rare parts were actually tougher to press in than the synergy were to press out. They were definitely a tight enough fit.
1eviljk likes this.
Rattler is offline
post #5 of 13 Old 04-29-2017, 09:34 AM Thread Starter
1eviljk's Avatar
Rare parts are up there in price with Dynatrac too. I've seen how massive the Rare parts are and wonder if I would have clearance issue with a newer beefier axle shaft. Has anyone had luck with Synergy ball joints and do the lowers sit almost close to stock?
1eviljk is offline
post #6 of 13 Old 04-29-2017, 11:29 AM
Dkjeep's Avatar
I have the carbon 44 front axle and it comes with those shafts that you purchased. It also came with synergy ball joints and there is no clearance issues. While the axle housing is not the same the geometry in that area has to be the same as you can re-use the stock knuckles etc....
1eviljk likes this.
Dkjeep is offline
post #7 of 13 Old 04-29-2017, 03:29 PM
Same here. Rare Parts non knurled installed after removing Synergy knurled. No issues!
Biginboca is offline
post #8 of 13 Old 04-29-2017, 09:59 PM
kjeeper10's Avatar
Good to know. My Synergy's went it pretty tight. Ive heard of people installing joints after Having Synergy's and they are loose.
Im going RP when these wear out.
1eviljk likes this.
kjeeper10 is offline
post #9 of 13 Old 04-30-2017, 06:30 PM
RedRubiconLJ's Avatar
Will those rare parts ball joints work with a RCV shafted D44?
RedRubiconLJ is offline
post #10 of 13 Old 04-30-2017, 06:46 PM
Yes, Synergy ball joints are sized closer to stock than most aftermarket ball joints. You do not have to grind the 2012+ axle shafts where you do for many ball joints.
1eviljk likes this.
christensent is offline
post #11 of 13 Old 04-30-2017, 06:48 PM Thread Starter
1eviljk's Avatar
Awesome, I messaged Austin over at Off-road brand to see if Synergy worked well with the Carbon Chromoly Shafts and they do. No grinding or clearance issues so I'm going to give them a shot.
1eviljk is offline
post #12 of 13 Old 04-30-2017, 07:03 PM
Yes no problem at all...
1eviljk likes this.
post #13 of 13 Old 05-01-2017, 02:37 PM
Thanks!
