Chirping Sound - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 04-15-2017, 03:40 PM Thread Starter
jkwebbie's Avatar
Chirping Sound
So I have noticed a weird chirping sound coming from the Jeep at idle. My Jeep is a 2012 Sport with a manual trans. At first I thought it was the throw out bearing so I looked it up on YouTube and saw where some guys have pushed the clutch in and the noise goes away. When I tired it, the sound was still there. Any idea of what this could be and how to fix it....besides an LS swap lol.
Thanks in advance guys!
jkwebbie is offline
post #2 of 8 Old 04-15-2017, 04:11 PM
Fklein6768's Avatar
Cheap guess is idler pulley or belt.
www.4x4s-pod.com
Fklein6768 is offline
post #3 of 8 Old 04-16-2017, 08:32 AM
Nucleophile's Avatar
With the engine idling, spray the belt with some brake cleaner. If it stops chirping, its the belt. If it continues its not the belt. (Next bet would be the idler pulley or water pump.)
You can use specific "belt dressing" sprays, but I have found they can make the belt slip over time.
Nucleophile is offline
post #4 of 8 Old 04-16-2017, 09:00 AM
Az Scooter's Avatar
Pushing the clutch in is the clue. Throw out bearing.
Az Scooter is offline
post #5 of 8 Old 04-16-2017, 10:44 AM
Did you read the OP, lol? He said pushing the clutch didn't affect the noise why would it be the throw out bearing?
Biginboca is offline
post #6 of 8 Old 04-16-2017, 11:11 AM
It's most likely the water pump. Had the same issue on my 2012. Had it replaced under warranty at 20k miles
CrazyLarry is offline
post #7 of 8 Old 04-16-2017, 06:25 PM
Az Scooter's Avatar
I misread it. That's what I get for scanning.
post #8 of 8 Old 04-16-2017, 06:38 PM
While you're checking things look for any signs of a coolant leak. I was searching for the cause of a belt chirp and from the stain could tell I had a radiator leak. Got the leak temporarily sealed with alumaseal while waiting for a new radiator and then changed the serpentine belt. Chirp stopped, I'm guessing the leaking coolant would get blown onto the belt while driving causing the chirp.
ScottW is offline
