Random No Start - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 03-08-2017, 08:25 AM Thread Starter
dhnate823's Avatar
Random No Start
Not sure if this should go here or not but ive been stumped lately with a random no start. Ive replaced the starter, the camshaft position sensor, the battery is good and ive checked as many grounds as i can find. It sounds as if something seizes up after turning the key and will go between that seizing noise and cranking for a bit then start finally. Im lost here.....its an '07 X 6spd. 2.5 RK X Factor 35's regeared to 4.88. Ive also installed a Spod with an Arb twin compressor under hood. Any info or help would go a long way. Thanks guys!
dhnate823 is offline
post #2 of 3 Old 03-08-2017, 02:54 PM
MoTech's Avatar
Seizing...hmm. Do a voltage drop across the positive and negative cables going to the block and starter. Could be your engine is drawing more current than the cables can provide; or, the cables have broken done and are not flowing enough amps. While cranking you don't want to see more than 1.5 volt drop across either cable. I recently had one that was a slow crank and the cable had eroded inside the insulation so it was difficult to detect.
If you have access to a high amp meter you should have about 200-250 amps while cranking. 400 + amps could indicate a mechanical engine problem.
MoTech
725-502-8507
MoTech is offline
post #3 of 3 Old 03-08-2017, 06:21 PM Thread Starter
dhnate823's Avatar
I didnt even think to check if its dropping voltage while starting. I'll check that next. Any idea if a bad starter switch could cause the weird sound? The no start is almost always accompanied by that mechanical noise.
