Coolant leak 2007 Wrangler - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 02-13-2017, 10:02 AM Thread Starter
Hey guys,
Having trouble identifying coolant leak, replaced radiator clearly that was leaking, but they discovered another leak, replaced intake manifold gaskets this weekend, still leaking, any thoughts?
DebGee is offline
post #2 of 6 Old 02-13-2017, 10:07 AM
Take pictures of where you see the leak at ie front or rear of motor some times you have to trace the path of the water flow which will follow the path of leak resistance.
Weep hole on water pump comes to mind when someone has a cooling system issue.
Tspevacek is offline
post #3 of 6 Old 02-13-2017, 10:27 AM Thread Starter
Will check that thanks!
DebGee is offline
post #4 of 6 Old 02-13-2017, 10:41 AM Thread Starter
No that wasn't it. I will try and take a picture, it looks like the drip in coming from the RH side probably a few inches back from the wheel
DebGee is offline
post #5 of 6 Old 02-14-2017, 05:51 AM
I wonder if it is the heater hoses.
post #6 of 6 Old 02-14-2017, 06:46 AM Thread Starter
I will check that thanks
DebGee is offline
