A couple beadlock /wheel questions - JKowners.com : Jeep Wrangler JK Forum
 4Likes
post #1 of 35 Old 02-12-2017, 09:48 AM Thread Starter
chitown35's Avatar
First, in lieu of spacer rings (I don't believe they're available for the two beadlock wheels I'm looking at) - any thoughts on using washers instead, if needed? I saw some of the guys on pirate do this too.
Second, how bad would it be to mount a 37" tire to an 8" wide beadlock? The tire specs want at least an 8.5" wide wheel.
||||||| 2015 Unlimited Sport S Baja Yellow
Auto / 4.56 Gears / ARB Front, Auburn Ected Rear Locker & LSD / G2 Core 44 35 Spline Axles / Alpine 9-Speakers & Sub / MC 3.5" w 6pak shocks / 37" KM3s on Method 105 Beadlocks
chitown35 is offline
post #2 of 35 Old 02-12-2017, 09:49 AM
robertcrav's Avatar
37x13.50 or 12.50
Sent from my SAMSUNG-SM-N920A using Tapatalk
ogutierr66 likes this.
2015 JKU Sport - 2.5" TF, Currie RJ44s, Detroit/ARB, 5.13s, Poison Spyder Aluminum Flares, Synergy MFG Bumpers, 37" Cooper STT Pros on KMC Machete Beadlocks, Warn 9.5cti
robertcrav is offline
post #3 of 35 Old 02-12-2017, 09:52 AM Thread Starter
chitown35's Avatar
Originally Posted by robertcrav View Post
37x13.50 or 12.50
12.5
Sent from my SAMSUNG-SM-G935A using Tapatalk
post #4 of 35 Old 02-12-2017, 09:53 AM Thread Starter
chitown35's Avatar
37x13.50 or 12.50
Although the specs list it at 13.
post #5 of 35 Old 02-12-2017, 10:12 AM
robertcrav's Avatar
You may have a little more "crown" to the tire but should be fine
post #6 of 35 Old 02-12-2017, 10:49 AM
Red face
You are going to run 37's on an axle designed for 35's so why are you concerned about running a tire on a wheel smaller then the manufacturer recommends?
Just being a smart ass. like said above more tire bulge which equals less clearance on the inside to frame and such.
post #7 of 35 Old 02-12-2017, 11:20 AM Thread Starter
chitown35's Avatar
Thanks. Was concerned with mounting difficulty too.
Any thoughts on the washers as spacers?
post #8 of 35 Old 02-12-2017, 11:25 AM
I am not sure where you are talking about putting washers.
post #9 of 35 Old 02-12-2017, 11:59 AM Thread Starter
chitown35's Avatar
Behind the beadlock rings to prevent space and side load on the bolts - heard that the bead is pretty thick on the STT Pros. Similar concept to the spacer rings that method sells for their 105s.
Not sure if they'll be necessary but I'd like to have a plan in place before I order.
post #10 of 35 Old 02-13-2017, 08:46 AM
Which wheels?
Check with OMF they may have spacers .
CT Performance, Inc is offline
post #11 of 35 Old 02-13-2017, 11:47 AM Thread Starter
chitown35's Avatar
Originally Posted by CT Performance, Inc View Post
Which wheels?
I was looking at the DV8 882 wheels or the new Quadratec SlickLock. Although now it looks like the latter is no longer available.
Anyway the only spacers rings available (even OMF) seem to be the wrong # of holes for either of those.
post #12 of 35 Old 02-13-2017, 04:40 PM
Nucleophile's Avatar
I am by far not an expert but I do use the plastic spacers on my Raceline beadlocks with MTRs. Very thick bead as well. If I didn't have spacers I don't know that I would use metal washers. First off you will need several for each bolt, especially for new tires. The beads tend to flatten out over time.
I would start with some thick, dense rubber washers. You are just trying to keep the bead ring "flat" and not tilted at some angle to the face of the wheel.
Nucleophile is offline
post #13 of 35 Old 02-13-2017, 04:45 PM
Just my opinion but don't use any rubber washers, either find proper spacers or as some of us have done change to another bead lock manufacture.
Steel rings will conform to thicker tire beads but again IMO not the best solution.
post #14 of 35 Old 02-13-2017, 06:44 PM Thread Starter
chitown35's Avatar
Actually I saw a recommendation to use those aluminum washer like spacers for this application, and company that sells them in all sizes.
But I have a few reservations about that too. I think I'll see if I can get ahold of a real spacer ring, or otherwise save some more and move on to potential wheel #4 in my search.
post #15 of 35 Old 02-14-2017, 08:15 AM
elusive's Avatar
don't take this the wrong way, but are you sure you need beadlocks?
I bet if you run an 8" wheel on 37's you'll never blow a bead... and if you do. just put air in it.
8" wheels are fine and they hold the bead better.
do NOT use washers or anything else to space out the ring. good beadlocks will have a ring welded on and if it's not there, it's really hard to get the tire centered and balance properly.
elusive is offline
post #16 of 35 Old 02-14-2017, 08:39 AM Thread Starter
chitown35's Avatar
It was more of a, I need new wheels anyway and airing down to 12 psi wasn't good enough, so while I'm at it I'm going to get some beadlocks.
post #17 of 35 Old 02-15-2017, 02:35 PM
TCdawg's Avatar
The MTR bead is actually not that thick. It's about 5/8". When I ran them on my Racelines with Steel rings I didn't need a spacer.
Pit Bull Rockers are a very thick bead, about 1.25". With steel rings I didn't need a spacer but those that use an aluminum ring usually do.
Just changed to 40" Cooper STT Pro's. Their bead is about 1" and I did use a spacer with Aluminum rings
TC
TCdawg is offline
post #18 of 35 Old 02-16-2017, 06:26 AM
SofaKing's Avatar
On my racelines, I use both their plastic spacer and a washer to keep my aluminum rings from coning.
2009 Silver Unlimited Rubicon -- Not really stock, anymore.
SofaKing is offline
post #19 of 35 Old 02-18-2017, 11:20 PM Thread Starter
chitown35's Avatar
Well I finally just said screw it and ponied up for the Method 105s and their spacer rings. A little more $ than I was planning on but I'm excited.
Dkjeep likes this.
post #20 of 35 Old 02-24-2017, 04:41 PM
BADWheels's Avatar
Correction: Good bead locks don't require any afterthought solutions because they are engineered for the customer's intended use from the very start.
Bead lock systems that physically clamp the tire from the outside leave critical fasteners in a seriously vulnerable region of the wheel and require increased vigilance due to the nature of how they work. A better method exists.
BADWheels is offline
post #21 of 35 Old 02-24-2017, 05:04 PM Thread Starter
chitown35's Avatar
I considered your wheels but couldn't find them for sale anywhere, they were much heavier, were very pricy, and looked difficult to mount IIRC.
post #22 of 35 Old 02-24-2017, 08:54 PM
Have you considered Hutchinson's? A little more expensive but the best wheel out there in every way. Can't believe they're not the go-to standard.
inline6 likes this.
christensent is offline
post #23 of 35 Old 02-25-2017, 06:03 AM
Hutchison are badass and you can't build a much heavier duty BL but they weigh SO FREAKING MUCH the non- SC'ed or LS'ed JKs (at least the non Pentastar ones)have trouble with them once any manner of 37 or larger tire is mounted .Just my opinion on Hutchison s
post #24 of 35 Old 02-25-2017, 08:12 AM Thread Starter
chitown35's Avatar
Yeah the Hutchinsons look nice but yeah heavy. And pricey, not in a backspacing I want, etc... Getting my current tires dismounted today to get ready for the method 105s which check every box.
post #25 of 35 Old 02-25-2017, 08:16 AM
They don't weight that much more then a standard Beadlock only a couple pounds more. I was looking for a lighter bead lock wheel and could not find one that would make much of a difference over the rock monsters.
