Does anyone know this hood scoop? - JKowners.com : Jeep Wrangler JK Forum
 2Likes
  • 1 Post By Rubi-8
  • 1 Post By upalms
post #1 of 13 Old 02-10-2017, 06:43 AM Thread Starter
upalms's Avatar
This hood scoop is on the Fab Fours site, but they don't sell it and don't know where they got it. Is it Mopar, Ford? I've seen similar scoops but not this one, the closest one I've found the dimenssions are too wide and go over the bumpers, it needs to be like 21 inches in the back. I get crazy heat coming off the engine in the summer and would love to open the hood up, plus I think it looks pretty ballsy
Thx
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
Synergy Front Suspension
Artec Front JK Armor
5:13's
Tom Woods Drive Shafts
Hi-Lift & Much More
2000 TJ
6" lift
37 TOYO MT's on Worx Rims
$hitty Built bumpers
Air Raid
Corbeau Baja RS seats
upalms is offline
post #2 of 13 Old 02-10-2017, 07:30 AM
Have you tried Jegs?
Why not just put louvers on it from Poison Spyder or Synergy and then maybe run an aux fan from underneath.
post #3 of 13 Old 02-10-2017, 07:41 AM
ronjenx's Avatar
These have solved all heat issues under my JK's hood; engine, transmission, electronic modules, air intake...
OEM Mechanical Fan Retrofit
MOPAR 42RLE Transmission Cooler Kit
ronjenx is offline
post #4 of 13 Old 02-10-2017, 08:25 AM
TOTL Innovations's Avatar
The problem is that that scoop isnt exactly designed to let heat out. At speed, it will actually force air in and swirl around the engine bay. At slow speeds, it will allow some heat out but isnt optimal. As others have mentioned, you may want to consider louvers if expelling heat is the primary goal.
This looks pretty close and should fit based on specs
https://www.amazon.com/Lund-80004-La...und+hood+scoop
- The most functional Jeep JK Hood on the market!
TOTL Innovations is offline
post #5 of 13 Old 02-10-2017, 08:53 AM
Treader's Avatar
You should open up your wheel wells like that Jeep as well. I'm sure that will let out some heat.
2010 2 door manual sport
Treader is offline
post #6 of 13 Old 02-10-2017, 09:22 AM
yobayn's Avatar
Thx
Ford
yobayn is offline
post #7 of 13 Old 02-10-2017, 09:54 AM
ronjenx's Avatar
Air into the engine bay through scoops and open wheel wells is air that doesn't pass through the radiator. Not a problem at low speeds and wheeling, but not good on the highway.
ronjenx is offline
post #8 of 13 Old 02-10-2017, 10:17 AM
Rubi-8's Avatar
The one pictured looks bad ass but I agree it might not help much.
It is awesome to physically see the heat waves come out of my TOTL hood when crawling.
ALso second the motion to open up your inner fenders. This made a huge difference in several of the Jeeps I wrench on.
TOTL Innovations likes this.
07 JK-8
08 2dr Sahara
17 Gobi Recon
Rubi-8 is offline
post #9 of 13 Old 02-10-2017, 10:42 AM Thread Starter
upalms's Avatar
Hey Guys thanks for the feedback, I'm at work I'll look through it when I get out. One thing I forgot to mention is I have the Daystar vents, I figured air in = air out. I know the poison spyder vent, but I thought the scoop looked cool and would also help
Rubi-8 likes this.
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
5:13's
Hi-Lift & Much More
2000 TJ
6" lift
Air Raid
upalms is offline
post #10 of 13 Old 02-10-2017, 11:46 AM
robertcrav's Avatar
Is the mechanical fan applicable to the 3.6??
Sent from my SAMSUNG-SM-N920A using Tapatalk
2015 JKU Sport - 2.5" TF, Currie RJ44s, Detroit/ARB, 5.13s, Poison Spyder Aluminum Flares, Synergy MFG Bumpers, 37" Cooper STT Pros on KMC Machete Beadlocks, Warn 9.5cti
robertcrav is offline
post #11 of 13 Old 02-10-2017, 12:23 PM
ronjenx's Avatar
Not the parts I used. There may be similar parts available for the 2012+ JKs that go to overseas desert locations. You would have to research that, as I did for the pre-2012 JKs.
ronjenx is offline
post #12 of 13 Old 02-10-2017, 09:42 PM
yes, I have asperger's
snout's Avatar
Putco catalog, page 4,297.
snout is offline
post #13 of 13 Old 02-10-2017, 09:58 PM
ronjenx's Avatar
Trying to get there.
Can you post a link to the page?
ronjenx is offline
