D30 pinion bearing install problems - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 02-10-2017, 02:09 AM Thread Starter
Hi all,
Jk 2012 2.8 CRD and I have problems to install the outer pinion bearing from outside ,because I couldn't get enough threads with the nut to pull it on
so it is mandatory to use the Miller tool 8112/8109 or i can use pipe on the bearing and tap it down the shaft of the pinion ?
thank you
Giacomo
giacomo.m is offline
post #2 of 12 Old 02-10-2017, 02:57 AM
KJV
KJV's Avatar
It sounds like you are referring to the inner bearing, as the outer is not a press fit. You will require a shop press to install the inner bearing. I certainly would not use a pipe and hammer.
2010 JKU. 3.5 RK Flex, 37" Nitto Trail Grappler MT, Method 105's. Poly Drag link, Fusion 4x4 Tie Rod, DIY Hydro Assist, Ultimate Dana 44 Front, Rubi 44 Rear. Ten Factory Chromoly Axles, EVO RockStar Skids 5.13's, VKS Shorty V2 with Warn HS9500i, EVO rear D-ring mounts, VKS Prerunner Sliders, Synergy Cage
KJV is offline
post #3 of 12 Old 02-10-2017, 03:51 AM Thread Starter
Thank you KJV
no ,it is outer bearing the one facing the drive shaft
Giacomo
post #4 of 12 Old 02-10-2017, 10:12 AM
Sgo70's Avatar
Did you try putting it in the freezer for 30 minutes or so, helps out a lot and should slide on. Not sure if I'm understanding correctly or not. I don't recall having any problems when I did mine.
Sean
Sgo70 is offline
post #5 of 12 Old 02-10-2017, 01:23 PM Thread Starter
Thank you Sgo70
" Did you try putting it in the freezer for 30 minutes or so " bearing or pinion ?
Giacomo
post #6 of 12 Old 02-10-2017, 01:47 PM
ronjenx's Avatar
Originally Posted by giacomo.m View Post
Thank you Sgo70
Giacomo
Is it the outer race that won't go into the case?
Or is it the inner race that won't go onto the shaft?
ronjenx is offline
post #7 of 12 Old 02-10-2017, 03:24 PM
Sgo70's Avatar
Yea sorry, I assumed it was the bearing that wouldn't go into the case. For this the bearing goes in.
If it won't slide on the shaft then the pinion goes in. The cold will just shrink it slightly.
Sean
Sgo70 is offline
post #8 of 12 Old 02-11-2017, 12:48 AM Thread Starter
It is the bearing that won't go onto pinion shaft
Giacomo
post #9 of 12 Old 02-11-2017, 08:08 AM
KJV
KJV's Avatar
The outer bearing should slide on with very little force. Hold the pinion gear and try pushing the gear on. It should not require any type of hammering or beating. Verify the part numbers on the bearing.
KJV is offline
post #10 of 12 Old 02-11-2017, 01:33 PM Thread Starter
" It should not require any type of hammering or beating. " in theory but if not you beat him there's no way to get him in the pinion
Bearing part number correct
Giacomo
post #11 of 12 Old 02-13-2017, 03:08 PM
Sgo70's Avatar
Did you try freezing the pinion? Should be enough otherwise I'd double check the part number on it.
Sean
Sgo70 is offline
post #12 of 12 Old 02-14-2017, 06:39 AM Thread Starter
Thumbs up
Thank you all
problem solved, just beat a little while someone holds the bearing on the other side
Giacomo
