1ton swap driveshafts - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 02-07-2017, 10:33 AM Thread Starter
Bodie's Avatar
What are you guys using for drive shafts with your 1ton swaps? I need a set that will go with my Super Duty Dana 60 and 14b rear. I was hoping someone made a set of shafts for the swap since they are so common nowadays.
Thanks!
2010 JKU Rubicon - 40s - Hesco SC - 60/14b - 5.38s - 3.5" RK - Artec - PSC - Yukon - ect
Bodie is offline
post #2 of 10 Old 02-07-2017, 12:08 PM
elusive's Avatar
for the rear I just used a Jk 1350 shaft available anywhere. I had it cut a little when I put the hemi in and it fit fine with a 14 bolt 1350 yoke.
I'm not sure about the front. the 1310 shaft I had is too long now.
I know I should buy a 1350 yoke for the 60, a new flange for the tcase, and a 1350 CV shaft, but I'm having a hard time justifying nearly a grand for a shaft on an axle that has locking hubs.
I'm thinking of trying to modify a super duty front shaft to fit or maybe just putting a 1330 yoke on the front driveshaft and have it cut a little.
edit..
$642
still a lot of dough
http://www.adamsdriveshaftoffroad.co...e-duty-series/
elusive is offline
post #3 of 10 Old 02-07-2017, 12:48 PM
Tweak's Avatar
I used the same tom woods 1310 front that I ordered from quadratec years ago when I had a dana 30. No changes were made to it. Just needed a 1310 yoke.
For the rear, I called up Adams and ordered a 1350 and ordered my own 1350 yoke. Gave them one measurement and it was under my jeep 2 days later.
A driveshaft is a driveshaft, it's just the dimensions that change. One ton swaps often involve wheelbase changes so there is no way to just click and order a driveshaft.
Billet 2013 2 door
Dana 60 front, 14 Bolt rear, ARB's, 5.38's, 40" sticky Trepadors, 3 link front and rear, 14" Sway-a-Way coilovers, Tom Woods 1310 front, Adams 1350 rear, PSC Hydro assist
Tweak is offline
post #4 of 10 Old 02-07-2017, 04:35 PM
Fusion 4x4's Avatar
You still need to measure, but we sell a bunch of driveshafts for these swaps. 1310 or 1350. We can usually adapt to any yoke you have as well.
Fusion 4x4 is offline
post #5 of 10 Old 02-07-2017, 04:47 PM
Adams 1350 front and rear 1350/1410
CT Performance, Inc is offline
post #6 of 10 Old 02-07-2017, 06:38 PM
I went with Adams as well. I went 1350 front and rear. I have a rear sterling and front d60 both of which have flanges and not yokes. Adams knew exactly what I had and was easy to deal with.
Sent from my SM-G920V using Tapatalk
Mattb19 is offline
post #7 of 10 Old 02-14-2017, 05:53 AM Thread Starter
Bodie's Avatar
I appreciate it guys.
I am going to look into using some Super Duty driveshafts and just have them lengthened/shortened to fit along with the right yokes. I guess if it doesn't pan out ill be spending $1400 on driveshafts...
Bodie is offline
post #8 of 10 Old 02-14-2017, 05:59 AM Thread Starter
Bodie's Avatar
So maybe two of these for the front and rear, and two SD driveshafts adjusted the the length I need should work. Ill update this thread with what I figure out.
29-2006: 1350 FLANGE YOKE-JEEP NP241 & ROCKTRAC REAR YOKE | Advance Adapters
Bodie is offline
post #9 of 10 Old 08-05-2018, 08:52 AM
This thread is relevant to my interests. I've got a set of super duty axles I'm rebuilding in my garage and was wondering the same thing. What some companies want for just driveshafts would eat my axle budget.
strokinout is offline
post #10 of 10 Old 08-06-2018, 05:33 AM
NeverLift's Avatar
I used Adam's front and rear.
Sent from my SM-G935V using Tapatalk
NeverLift is offline
