Steering issues? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 01-10-2017, 04:53 PM Thread Starter
Steering issues?
Running 38x14.5's on a 2015 JK and a while back noticed the steering wheel was ridiculously difficult to turn while sitting in still at idle on rough blacktop. Revving up was not really much help, it was so bad my wife actually could not turn the wheel. If the vehicle is on a smother surface like a garage floor or moving at all, the steering works very easy as you would expect. The only other possible info that may be relevant is the front axle was switched to a Dana 60. I have installed a complete PSC system which works great, The reason for the question is I have a friend that wants the old box and I don't want to give it to him if it could be a problem for him.
Super Macho is offline
post #2 of 4 Old 01-10-2017, 06:09 PM
ALASHA's Avatar
I am confused. You had a steering issue as described. You then upgraded to a 60 and a complete PSC system so now no problems. Is that correct?
Did you pull the old box and pump off? Im leaning towards a blown pump as a guess for the cause...
ALASHA is offline
post #3 of 4 Old 01-10-2017, 07:42 PM
Tweak's Avatar
The pump was the likely culprit.
Billet 2013 2 door
Dana 60 front, 14 Bolt rear, ARB's, 5.38's, 40" sticky Trepadors, 3 link front and rear, 14" Sway-a-Way coilovers, Tom Woods 1310 front, Adams 1350 rear, PSC Hydro assist
Tweak is offline
post #4 of 4 Old 01-10-2017, 08:40 PM
I would replace the fluid first. If there's no change, the pump might not just throwing enough fluid at idle.
karlduke is offline
