ECU/Main harness issue - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 01-10-2017, 02:16 PM Thread Starter
Guruman's Avatar
Question ECU/Main harness issue
2013 JKRU RIPPed
I've been having intermittent issues with a code telling me my o2 sensor is too rich (mostly p0297 over and over). Been around the horn several times with RIPP.
I recently had the 3.6 replaced with a low mileage pull due to an unfortunate incident with water ingestion....
I ended up paying a local shop to do the swap. So, different motors, different sensors, different everything.
After the swap I had a few remaining bugs.... mainly o2 sensor voltage high bank 2 sensor 1, persistent....
So I swap out the sensor, same thing...
Today, I start looking into the wiring, figuring the guy that did the swap might not have been as careful as I would have and he's pinched a wire, or bent a connecting pin or something.... can't find anything. Until...
I have the Jeep sitting with the key on, but not running, while I'm checking the wiring (using the Torque app to monitor the O2 sensor voltage in real time)...
I'm checking for damage to the harness and or loose connectors up near the ECU when the Torque app begins reporting error codes (19 in all) everything from throttle sensor to oil temp, to ignition faults and misfires (all while it's not even running)
Messing with the main harness leading off the right side plug of the ECU causes all sorts of hell to break loose every time, but I cannot find any damage to the harness.
My thoughts are ECU? or possible the plug? Plug looks OK though.
Any suggestions? A search turned up nothing useful.
_
Guruman is offline
post #2 of 2 Old 01-10-2017, 06:39 PM
0lllllll0 RPMEXTREME's Avatar
The right side connector is the engine side harness so that does make sense. I would try and hold the harness still and only move small portions of it until you narrow it down.
Im guessing a ground splice has come loose inside the harness somewhere.
