Skid Plate questions - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 07-27-2010, 01:10 PM Thread Starter
I'm a newbie on this - have a 2010 Sahara 4 door. Thinking of adding some skid plate protection underneath - what is the most important? What should be done first? Recommendations?
TKs
pemberton is offline
post #2 of 6 Old 07-27-2010, 01:13 PM
Jagrmaister's Avatar
Order up the river raider set and be done with it. I've got a 6spd Rubi, so mine just came with the transfer case skid and the gas tank skid otherwise I'd have their set. The 2 stockers worked fine out at Badlands all weekend. With a lift, my oil pan and trans were pretty far out of harm's way. I'd still like to get one for those locations, though.
2010 Jeep Wrangler 2dr Rubicon with a part from everyone...
Jagrmaister is offline
post #3 of 6 Old 07-27-2010, 01:22 PM
slacktide's Avatar
I would save up and buy the whole set at once.
Im running rock hard and they work well. But there is a lot out there and im sure most of them are good
Poly performance
River raider
Poison spyder might have something to??
slacktide is offline
post #4 of 6 Old 07-27-2010, 03:09 PM
BumpInTheRoad's Avatar
River Raider has their full skid package on sale now, 10% off. I just ordered one up for my 4-door. This will cover your oil pan, engine, trans, transfer case and gas tank. If you don't go with a complete kit, at least get something to protect your oil pan. Jeeps don't run well with no oil.
Relocate your steering stabilizer before you bend it. Relo brackets run about $50 from a variety of manufacturers, or $100 if you wait too long and bend the shock. If you've decided on what lift you're eventually going to buy, get the relo bracket from that manufacturer to ensure it's compatible with any trackbar bracket you'll need later.
Lower control arm mounts are vulnerable. You can buy a bolt-on kit, but weld-on is better. For around $100 plus a six-pack of beer you can get a local welder to just weld-in scrap 1/4" plate to the front and rear mounts, then bring it home to sand, prime and paint.
Evap Canister needs to be skidded or relocated. Poison Spyder has what I think is the best skid.
Front and rear differentials should have beefier covers. The OEM stamped steel covers are thin.
You don't have rock sliders or rocker protection. I'd suggest getting sliders -- Rubicon take-offs are good and usually cheap -- high your list.
I'm a JKO Reject
BumpInTheRoad is offline
post #5 of 6 Old 07-28-2010, 12:13 AM
Rubydak's Avatar
The River Raider full skid plate system is very complete and stronger than hell.
2008 Rubicon, 4 door Detonator yellow, 3.5" lift, Motech LS 6L engine conversion, RR Skids.
Rubydak is offline
post #6 of 6 Old 07-28-2010, 09:06 AM
Bumpintheroad makes some good points. The EVAP definitely needs remounting or a skid. Do yourself a favor and get a set of differential covers. Rock sliders are a must.
As for the skids, it makes sense to get them all at once and save some $$$. I wouldn't be too worried about your control arm mounts. Extra protection would be nice, but definitely not necessary. Same with oilpan and trans skid. I definitely want one for the oilpan, but I went through a hell of a lot of stuff on a run this weekend and most things up front stay up and out of harms way. Of course, I have a 3.5" lift and 35s, so I'm not exactly stock level. Your fuel tank will take a beating, and the diffs will catch. Rock guards anytime you approach those longer wheelbase obstacles. Buy these to play: RR skid set, Rock rails, Diff covers, relocate/skid EVAP. Done...and broke.
