annoying squeak coming from driver rear - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 07-27-2010, 12:37 PM Thread Starter
so i started noticing an annoying squeak coming from the driver side rear of the truck. got out and rocked it side to side and sure enough it was loudest when i shook it from the driver rear. it was too dark to check it out last night and im at work now... any ideas what it could be before i get under there? its had a 2.5" TF BB for a few weeks now but havent heard the squeak until now
Linkphotography is offline
post #2 of 9 Old 07-27-2010, 12:42 PM
e-jeep's Avatar
Feedback: 12 reviews
I recently had a streange squeek in my JEEP. Could have sworn that it was coning from the rear passenger side ...maybe lift, maybe bumper. Finally located the squeek inside my JEEP. It was coming from the rear passenger seat. So I tightened fown all the bolts, sprayed them with WD40 and slapped some white lithium grease on the bar that locks the seat upright. No more squeek in my JEEP.
My Build Thread ~
NE Trail Ride Thread ~
Adrenaline Offroad
e-jeep is offline
post #3 of 9 Old 07-31-2010, 11:05 AM
jeepRcreepR's Avatar
I have the same BB and I have a squeak in the passenger rear. Someone said that it could be the bolt that holds the shock in place is not tight enough. I have yet to try and solve the problem, but I may look into it today. I'll let you know how it goes.
Edit: While rotating my tires just now I found the source of my squeak. It seems that the sway bar, right before the link, is rubbing on the female brake line connector because the tension from the link/swaybar is pushing on the brake line and is moving the brake line bracket back about 5 mm or so.
So now the question is, how do I take care of it? (for anyone that has a solution, please help)
07 JKU Rescue Green with 3.5" RK Mid-Arm Flex w/ Bilstein 5100s, 5.13's, Eaton E-Locker, 35" MT Baja ATZ, 17" DC Torque wheels, Monstalined tub, Home-made front bumper with Smittybilt XRC-8 winch, Wild Boar rack w/ IPF 968 lights, K&N Intake, Gibson Exhaust.
Future Mods: 2wd-4wd conversion = completed!
jeepRcreepR is offline
post #4 of 9 Old 07-31-2010, 11:00 PM
I just got the TF 2.5 coil with shocks put on and its been squeaking the whole time by all 4 corners...i only have about 50 or 60 miles on it so far and im also confused on why its squeaking... maybe needs to be broken in cause everythings new?? or some wd40 somewhere?? I did get new balljoints at the same time...I need help as well!!
08 Jk is offline
post #5 of 9 Old 08-04-2010, 06:33 PM
I would check to see if your brake line is rubbing on anything like mine is. That might be a couple of the squeaks in the rear. The easiest way to do it is to jack it up, take of the tire and gently pull down on the rear bumper. I was able to pinpoint the noise right to the brake line rubbing on the sway bar.
good luck
post #6 of 9 Old 08-05-2010, 09:44 PM
bluerubicon08's Avatar
I had the same squeek coming from the passenger side...........told the bitch to get out, and haven't heard it since
If you're gonna be fucking weird, own it.
~SoCo
______
bluerubicon08 is offline
post #7 of 9 Old 08-05-2010, 11:57 PM
I found the fuel filler got a squeak up sometimes.
Removed the tail light and cable tied the fook out of it.
ex: RHD JK 2dr CRD auto
CRDTom is offline
post #8 of 9 Old 08-06-2010, 01:06 AM
zjr
zjr's Avatar
First, quit eating beans.
Second, tell the kids to shut it.
Finally, it is very possible it is the lift... When I put mine on, I used some elbow grease on the brake line mounts. It was required to bend the small bracket away from the other moving parts.
zjr is offline
post #9 of 9 Old 08-06-2010, 02:00 PM
WeBeRockin's Avatar
Annoying Squeak
Dude, since doing a couple of 4's a few weeks ago, I've had an annoying squeak on driver's side. Thought it was a front brake squeaker, but just figured out it's a bent rear axle that is causing my disk to contact the pad every rotation. Hopefully yours is not the same issue.
WeBeRockin is offline
