Poison Spyder Crusher Flares or River Raider Fenders - JKowners.com : Jeep Wrangler JK Forum
post #1 of 44 Old 07-27-2010, 01:32 AM Thread Starter
I was just wondering if anyone had any comments on which ones they prefer as far as engineering and style. I'm ready to pick some up. PS has some inner brackets for extra support etc I read so maybe those are designed a little better (??) thanks
Lotus03 is offline
post #2 of 44 Old 07-27-2010, 06:40 AM
Dr.Dirty's Avatar
Feedback: 21 reviews
I have not seen the RR ones up close. I have seen many sets of the PSC and they are top quality and the fit and finish is second to none
www.jeepasylum.com
Dr.Dirty is offline
post #3 of 44 Old 07-27-2010, 08:05 AM
Openly Hostile
I can only comment on the PSC, I really like mine. Rears coming as soon as they finish my set up.
SDMF is offline
post #4 of 44 Old 07-27-2010, 08:13 AM
terrahawk's Avatar
Both are high quality products you'll; be happy with either one.
terrahawk is offline
post #5 of 44 Old 07-27-2010, 08:38 AM
Moose512's Avatar
Do you plan on parking on top of them?
River Raider and PSC both make great stuff and are both great people to deal with. When it came to the flares I am partial to the PSC...
Moose512 is offline
post #6 of 44 Old 07-27-2010, 08:54 AM
Jagrmaister's Avatar
I'd love to get a set of either! Probably would go PSC, though, just like the angled design a little better. Both would more than likely be top-notch quality.
2010 Jeep Wrangler 2dr Rubicon with a part from everyone...
Jagrmaister is offline
post #7 of 44 Old 07-27-2010, 04:45 PM
Kiltstain's Avatar
If you go with PSC prepare for a long semi-custom install. But awesome once they are on. I've heard RR install is easy
2007 Sahara 2dr, 3.5" RK X Factor Plus Long Arm, Dana 44 Rubicon front axle w/locker, Dana 44 Rear, Poison Spyder BFH w/stinger, Poison Spyder fenders F&R, Poison Spyder Rocker Knocker, 37" Pitbull Rockers Bias Ply, 17x9 Spyderlocks, 1350 Drive shafts, Hard Rock 4x4 Rear bumper w/tire carrier & gas can mounts, Poly Pro front axle tube, Poison Spyder evap skid. Upcoming: RR Snorkel, Skid plates
Kiltstain is offline
post #8 of 44 Old 07-27-2010, 07:28 PM Thread Starter
not really interested in a long custom install for the fenders right now. Both look great and like both companies a lot. Thanks for comments
Lotus03 is offline
post #9 of 44 Old 07-27-2010, 07:51 PM
Mr.RonGilbert's Avatar
Can't go wrong with either IMO... both are great products. I do like the option of having the RROR's epoxy lined from the shop.
Mr.RonGilbert is offline
post #10 of 44 Old 07-27-2010, 08:02 PM
maverick's Avatar
Semi-custom? How do you define "semi-custom"? I believe you are misleading. I love my PSCs!
maverick is offline
post #11 of 44 Old 07-27-2010, 08:06 PM
I hear that they can be installed by whiskey swilling hotties......
post #12 of 44 Old 07-27-2010, 08:12 PM
Openly Hostile
The install was pretty straight forward on my fronts, it took a few hours taking my time by myself.
SDMF is offline
post #13 of 44 Old 07-27-2010, 09:06 PM
block's Avatar
both are awesome ,i love psc stuff... but i went with the river raider flares..i really liked the angles .. they are very strong also
block is offline
post #14 of 44 Old 07-27-2010, 09:07 PM
zjr
zjr's Avatar
Going with PSC.
zjr is offline
post #15 of 44 Old 07-27-2010, 09:13 PM
andrelopez99's Avatar
Post
Hey block what's the name of the color on the wheels and body armor. Paint or powder coat.
andrelopez99 is offline
post #16 of 44 Old 07-27-2010, 11:31 PM
cruzcode's Avatar
I think most rig owners are going to tell you what they purchased is the best. But, collect enough opinions with accompanying details, and you'll hopefully have enough information to make, well..., an informed decision.
I went RROR and have been pleased. I think if you go RROR or PSC, you won't be going wrong, and either will take you the better part of a day or two to install, depending on if you have help or not. Either way, be patient, clamp, measure, step back, evaluate. Then, take a break, re-evaluate, make adjustments, re-clamp, re-measure, and re-evaluate. Then mark and drill.
If you'd like to see the River Raider fenders on my rig, check out my build...
https://www.jkowners.com/forum/showthread.php?t=32642
RC
A lot of chit coming...
W9DRC
cruzcode is offline
post #17 of 44 Old 07-28-2010, 01:11 AM
desert dog's Avatar
I have the PSC flares. They are tough and can take a hit and they look sexy for sure.
But.....install was a nightmare. Holes did not line up on mine and they made the sheet metal wavy above the front fenders. Fit was so bad on my rears, that I couldn't even use the rear braces. I am going to modify the rear braces to make them work.
Once I got them on, I have been very satisfied with their function. I repaint them once in a while and they look new again.
The RR looks good too, but I have no personal experience with those.
desert dog is offline
post #18 of 44 Old 07-28-2010, 06:22 AM
maverick's Avatar
I have both the front and rear supports and installation went fine without modification. I will say, it did take some effort, but installation was okay.
maverick is offline
post #19 of 44 Old 07-28-2010, 09:54 AM
biglar's Avatar
I’m kinda partial to the Poison Spyder Crusher Flares. It seems the 2 door guys are having issues with the install and the four door guys aren’t. Our 3D models from Chrysler show the installs to be the same, so we’re somewhat baffled. We’ve installed several 2dr flare sets here at the shop and have had no issues. We even had Marcy and Cortney install a set on JKO TV. Even though Chrysler says they’re the same, we know in reality that no two Jeeps are identical. Because of this we have run across situations where redrilling the factory holes is easier than trying to make them work.
Our install is more complex than a set without inner support bracing, but I think you’ll find it well worth the effort. Why use a metal flare if it’s not supported by more than the VERY thin factory outer skins? You can’t really call it armor if it’s not supported. We a very happy to answer any install questions you may have. A phone call may save you from a semi-custom install.
Thanks for considering our Crusher Flares and don’t hesitate to call if you have any questions.
Larry McRae
951-849-5911
Connect with us on:
biglar is offline
post #20 of 44 Old 07-28-2010, 12:16 PM
RIP Brad
abendx's Avatar
I have set of the PSC flares. I can't comment on the RR ones, as I have never seen a set, but can make some comments on the PSC ones.
The lines of the PSC flares match the lines of the JK better than anything else out there that I have seen in either pictures or in person.
The PSC flares are stout. I know this because I have laid my junk into plenty of rocks and have given them some major gouges.... yet not a hint of any body damage or deformation. Hell... Larry had another Jeep parked up on his.... really, does there need to be any other indication of how strong they are?
Several of my wheeling buddies have seen first hand how I abuse the PSC flares and have in turn gotten them as well. Can't give much more of a recommendation than that.
abendx is offline
post #21 of 44 Old 07-28-2010, 12:32 PM
maverick's Avatar
YES. Larry needs to take the forklift... push against the flare until scooting the JK sideways... then, while scooting the JK sideways lift up on the flare as to tip the JK over. Such a video would certainly be CONCLUSIVE.
maverick is offline
post #22 of 44 Old 07-28-2010, 01:07 PM
jdale75's Avatar
I would only be satisfied if the forklift was being driven by a guy in a gorilla suit, and in the background, there's a female midget spanking a pig. IMO.
jdale75 is offline
post #23 of 44 Old 07-28-2010, 02:05 PM
zjr
zjr's Avatar
Anyone have a gorilla siut for me to borrow for a month. I promise I'll return it, and there will be a vid of Larry shitting his pants...
zjr is offline
post #24 of 44 Old 07-28-2010, 05:13 PM
desert dog's Avatar
Yep, you sold me on them when I watch you lay your jeep agaist the wall at BC109, then drive through with only scratched paint on the fenders.
Im just glad Im not ripping off the plastic ones anymore. Chasing those damn things down every weekend was getting old. I would have lost them again this weekend.
post #25 of 44 Old 07-28-2010, 05:17 PM
RIP Brad
abendx's Avatar
Well then, seeing you were getting a stiffy over my rear the other day.... I have something else for you to switch to as well. PSC will have a new weld in cross member to strengthen up the area where I hit mine. Soon brother!
abendx is offline
