Any info for 6-spd to automatic swap? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 104 Old 07-26-2010, 07:35 PM Thread Starter
jtrain's Avatar
I have picked up a 2009 automatic trans, harness, shifter, etc. for this swap.
I know it will have to be taken to the dealer for a program. Has anyone done this? Also, will I need a new computer for the swap? It is the one thing I didn't get. Any info would be greatly appreciated.
Reasons I am going to the trouble:
1. I sold the manual trans for more than the auto and parts cost me
2. My wife will be able to drive it
3. Rubicrawler, so I won't have to regear my axles (currently 5.13s and 40s)
4. The labor of putting my old trans into another jeep offsets the Rubicrawler by a good bit
5. Do I need another reason?
jtrain is offline
post #2 of 104 Old 07-28-2010, 02:37 PM
RedrockHemi's Avatar
Send a message via Yahoo to RedrockHemi
you will also need a condensor with an auto trans cooler in it and tranny cooler lines
08 Red Rock Rubicon Unlimited, 5.7 Hemi, 4.88's, 3.5 in Nth Deg short arm, 35in KM2's, AEV Pintler Beadlocks, Teraflex diff covers, Ruff Stuff Custom tie rod, AEV corner guards painted to match, painted flares, painted hardtop, leather seats, AEV front bumper painted to match, Warn 9000 XDi, Mopar Rear w/swingaway painted to match, HID's, TMD cowl Induction hood, Nemisis Billy Rockers, Warn Dual modes up front, PIAA's on the windshield
RedrockHemi is offline
post #3 of 104 Old 07-28-2010, 02:45 PM
Actually a stand alone cooler will work just fine rather than swapping the radiator out.
Assuming there is a control module associated with the automatic. As well as a different set of pedals, shifter assembly, etc.
post #4 of 104 Old 07-28-2010, 06:59 PM
tkob1060's Avatar
tranny cooler isnt in the radiator, its in the bottom quarter of the a/c condenser.
I still think I would do it without changing the condenser though, but add a trans cooler with fan built in.
tkob1060 is offline
post #5 of 104 Old 07-30-2010, 06:06 AM
jeepdork's Avatar
I have thought about doing the same thing with my 07. Keep us posted on how it goes and what it takes.
jeepdork is offline
post #6 of 104 Old 07-30-2010, 06:26 AM Thread Starter
jtrain's Avatar
The B&M 70297 cooler will be here today. It is 13.5"x9" with a 9" fan that is enabled at 175 deg.
jtrain is offline
post #7 of 104 Old 07-30-2010, 03:57 PM
WHY? JEEPS need manual!
it's not a liberty!!
yellow rubicon is offline
post #8 of 104 Old 07-30-2010, 04:02 PM
mckbrew's Avatar
Really???
mckbrew is offline
post #9 of 104 Old 07-30-2010, 04:16 PM
BeerMonkeY's Avatar
well of course they do, just look at all the manual shift rock crawlers out there.
im in the same boat, id rather drive a stick but its easier for my wife to drive a auto and easier for her to tow the camper and to wheel.
theres a good motto to go by in married life
happy wife, happy life.
'92 YJ
'13 WK2
BeerMonkeY is offline
post #10 of 104 Old 07-30-2010, 04:17 PM
BeerMonkeY's Avatar
maybe look into drive shafts? might be different lengths, also the skid plates are different to. and the center console
'92 YJ
'13 WK2
post #11 of 104 Old 07-30-2010, 04:29 PM
desert dog's Avatar
desert dog is offline
post #12 of 104 Old 07-30-2010, 07:35 PM
Broncojohn's Avatar
There were a few that finished KOH
Broncojohn is offline
post #13 of 104 Old 07-30-2010, 07:59 PM Thread Starter
jtrain's Avatar
I have the console, rear driveshaft is undecided. Front shaft is already a 1310 cv, and may have enough to spare either way, we'll see.
jtrain is offline
post #14 of 104 Old 08-06-2010, 11:15 AM Thread Starter
jtrain's Avatar
Removed the manual transmission and transfer case and installed it in the 2wd customer's JK yesterday. Now awaiting reassembly with the auto.
jtrain is offline
post #15 of 104 Old 08-06-2010, 11:58 AM
I would swap for another wife before swapping to an auto. First date with my wife we rode motorcycles, she kicked ass, I married her. Never had a lame bike or car with an auto in our 20 years together.
DesertJK is offline
post #16 of 104 Old 08-06-2010, 02:31 PM
Ken Jong Il's Avatar
I'm in the process of doing the same swap. I'm currently gathering parts and it's actually going to be an extremly cheap mod. Good call on the stand alone oil cooler. It will work considerably better than the factory one and it will save you a few hundred $. You do need to purchase a brand new computer. The dealer will need to put a fresh burn into the new ECU with the automatic shift points and they will also be able to burn in your VIN so that it's all legit. Have you picked up the shift interlock cable for the steering column? There will be no issues with driveshaft length so don't worry about that. Also don't forget the shifter lever sled (or bracket) you'll need the automatic version so you can plug the hole on the floor where your manual shifter came through. The programming was my biggest concern because the security system talks to the ECU and allows you to unlock and start your jeep. Now that I found out that the dealer can burn and flash the fresh ECU with all the info I'm all in on doing the swap. I'll keep an eye on your thread and we can trade info and all the in's and out's on pulling this off
07 Rescue Green Unlimited
Upcoming projects - Much needed TLC
Ken Jong Il is offline
post #17 of 104 Old 08-06-2010, 02:39 PM
Openly Hostile
Curious why they have to flash a new ECU instead of just flashing the current one to shift the transmission?
Jason
SDMF is offline
post #18 of 104 Old 08-07-2010, 09:43 AM
Well first off they are two different computers. Second, the architecture on the PCM is reflashable, certain information is, but the initial burn cannot be altered. Shifting isn't the issue to begin with, it's the VIN information on the PCM that is the concern. Technically I could just score anothe ECU from any Rubicon and be good to go, but my security wouldn't recognize the VIN and then I wouldn't be able to start my Jeep. Trust that alot of "outside the box" thinking has gone into committing to this project and the one undeniable fact is...a new PCM is required
post #19 of 104 Old 08-07-2010, 03:31 PM Thread Starter
jtrain's Avatar
Sounds good, I haven't got the PCM yet, but do have the shifter sled. I will probably wait until I tow it to the dealer to get the PCM.
jtrain is offline
post #20 of 104 Old 08-08-2010, 04:02 AM
fishinmagician's Avatar
what a pita. I would have traded it in on an auto or taught your wife to drive standard, there are videos on you tube to help her.
fishinmagician is offline
post #21 of 104 Old 08-08-2010, 11:14 AM
Did you have any issues getting the correct sfifter sled? COP 4x4 tried ordering one 4 times and never got the right one. I guess theres issues with the part numbers in Chryslers parts system
post #22 of 104 Old 08-08-2010, 12:11 PM
dsy
dsy's Avatar
...........................................Thats the problem right there ^^^ 52060490AD is the sled I used for mine. Worked great.
07 Flame Red Unlimited Rubicon, 5.7 hemi, RCV shafts, 35" KM2's, AEV 3 1/2 lift, , AEV rear swing away Carrier, AEV Snorkel, LoD front bumper with Warn powerplant, 45qt Engel refrigerator / freezer. , Marchal E-Code lamps
DIY Hemi build
dsy is offline
post #23 of 104 Old 08-08-2010, 12:27 PM
Send a message via MSN to JTs-JK Send a message via Yahoo to JTs-JK
My wife wants to get his and hers Jeeps but wants to learn to drive a stick first because she said "Jeeps should not have autos"
JT
JTs-JK is offline
post #24 of 104 Old 08-08-2010, 05:10 PM
Juanhinestrosa's Avatar
What is the cost of this mod? if its a reasonable, then I am willing to switch my auto for a 6-speed.
2010 Jk Unlimited Sport
35" Mickey Thompson Tires
Magnaflow exhaust
Fortec suspension 2.5"
Airaid CAI
Hi-Lift
IPF 968s windshield mounted lights
HID lights
5.13 G2 gears
Poison Spyder Rear Diff Cover
Juanhinestrosa is offline
post #25 of 104 Old 08-08-2010, 06:17 PM
jeepdork's Avatar
cost
I'd be interested in a price list on where you guys are at now too. What do you think the total cost is going to be?
jeepdork is offline
