Need help with some G#D D$*#M Nutserts!!! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 07-25-2010, 09:03 PM Thread Starter
Does anybody have any experience with installing EVO crusher corners. I can't get the damn nutsert to not spin. Are nutserts suppose to collapse in on itself or what? I am to the point of just buying bolts and drilling all the way through and forgoing the nutserts.
9. Fully thread the long bolt with nut into the nutsert as seen in photo. With wrenches hold the bolt stationary and turn the nut 2 - 3 turns making sure that the nutsert does NOT turn.
Joe
Det. Yellow 4dr Rubicon
martij3 is offline
post #2 of 9 Old 07-25-2010, 09:06 PM
terrahawk's Avatar
PM bodyguy. He just welded those pieces of shit on. River Raider uses well nuts which worked out pretty well for me.
terrahawk is offline
post #3 of 9 Old 07-25-2010, 09:27 PM
Are you using a nutsert insert tool? they have to be compressed like a rivet.
post #4 of 9 Old 07-25-2010, 09:32 PM
Heat'n and a beat'n...
STUPIDFACE's Avatar
That piece of shit that they call a tool that they include was useless to me. I got a setting tool from harbor freight. They were still a pain in the ass to set the nutserts.
corey d
corey d
2008 JEEP...
STUPIDFACE is offline
post #5 of 9 Old 07-25-2010, 09:46 PM
jdubb75's Avatar
Rivet nuts/nutserts can be a PITA to collapse. I'm not sure what the tool looks like that you got with the kit, but if you search the web for "rivet nut tool" you can find a cheap little tool that will do the trick. It looks like two wedges that slide against each other. I had to set some 12mm rivet nuts and couldn't find one of the ramp style tools for that large of a thread so I had to make my own at work. They were hard as hell to collapse, but it worked.
Good luck!
***EDIT***
Actually, this is the tool I was thinking of.
http://www.rivetnuttool.com/
jdubb75 is offline
post #6 of 9 Old 07-25-2010, 10:18 PM
andrelopez99's Avatar
What size are they?
I have this tool, I used for the PSC body armor, it works REALLY WELL compared to the "tool" supplied
Use an electrical drill with adjustable torque, no torque wrench.
andrelopez99 is offline
post #7 of 9 Old 07-25-2010, 10:20 PM
Good luck!
***EDIT***
LOL, DUDE I didn't see your post..
post #8 of 9 Old 07-26-2010, 08:57 AM
knyland's Avatar
https://blindrivetsupply.3dcartstore...604_p_823.html
This thing right here is what kept me from burning the jeep to the ground. Order the proper head for it and you will be set. I destroyed the harbor freight one first try. give the guy a call he was awsome to deal with.
This is one reason I have a strict policy of not eating anything out of another dudes butt. Flick it with my tongue? Sure. Run my tongue around the rim? Depends. Dart my tongue in for a brief second? Maybe. Eat something out of it? No fuckin' way!
If you want to know whats on it check my
knyland is offline
post #9 of 9 Old 07-26-2010, 05:19 PM
Mr.RonGilbert's Avatar
Mr.RonGilbert is offline
