poly performance track bar brace
anyone run this on their rig? I like that its a brace and ss relocator all in one. curious to see if anyone has anything bad to say about it.
http://www.polyperformance.com/shop/...t-p-16402.html
Sponsored Links | |||
Advertisement |
I installed one on a buddys jk, easy to install and worked great.
Edit on the welding comment. It can be welded for those that don't read instructions
bodyguy - you sure about the welding? I don't think you have to weld this...it's all bolt on. Now you could weld for strenght, but it's not necessary.
- Ruskin
Advertisement |
Originally Posted by Ruskin
View Post
Originally Posted by bodyguy
View Post
Yeah your correct, I don't read directions. I partially welded the track bar bracket on and removed the factory sway bar tab and welded the new one on. I guess I could have saved a little time but atleast I don't have to worry about the bolts coming loose
I have it and it works just fine. You can also use it a point to mount a hydro assit if you go that route down the road, but I'd weld it on at that point. I did the the whole re tube and mount deal on the front end. It drives better and the feel is a lot more soild on the highway now the front end is straight. I've had no problems with Poly Performance and think they have well thought out products, glad I went this way with mine.
I ordered the whole steering kit for 300, 1/2 of the kit is this. I also got the front upper brace as well ad the rear brace/raise kit. Ups says it will all be here Monday. Planned on doing a write up with a review as well. The Aev drop prackets did nothing but create a severe pull to the right, even after adding the front lower adjustable with the passenger side extended it still pulls. I can't wait to get those brackets off! Anyway I'll start a thread in a few days on them.
2008 JK 4Dr Rubicon
Stone white
Mygig W/Uconnect working.
Hard top/Auto tranny
First mod, dog slobber.
Painted hard top
Spidertraxx 1.5 spacers
Teraflex 3" lift
Slow and Low
I've got a TF 4" on my UL, but added Poly's steering kit with this bracket & the drag link flip. Highly recommended.
Feedback: 9 reviews
Poly track bar bracket
Have it, love it, no welding, you must do the draglink flip in order to keep geometry in check. I am running it with a RockKrawler draglink.
Advertisement |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
