2 door 6 speed - If you have one please read - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 07-23-2010, 05:59 PM Thread Starter
So I'm looking at putting a 1 inch body lift on my 2 door 6 speed - I already have an OME Lift and do not wish to do any more of a suspension lift as I don't want to have to get new drivelines and such right now - thus I am looking at a BL
I have searched
There seems to be lots of posts about BL's being very bad on a 2 door 6speed.
So I am curious to hear from anyone who has a 2 door and a 6 speed with a body lift.
How much of a Body Lift did you use?
Do you have any troubles?
Does it pop out of gear?
Thanks!! I appreciate any and all input
JonP is offline
post #2 of 14 Old 07-23-2010, 06:54 PM
BeerMonkeY's Avatar
what about trimming your frnders a bit instead of body lift
'92 YJ
'13 WK2
BeerMonkeY is offline
post #3 of 14 Old 07-23-2010, 07:57 PM
s10x1000's Avatar
I have a one inch body lift on my 2 door and I did not trim the boot.
It sucks going into reverse no other problems and im sure if I would trim the boot on the shifter it wouldnt have any problems going into reverse.
s10x1000 is offline
post #4 of 14 Old 07-23-2010, 08:02 PM
dmhines's Avatar
Pass on the body lift ... just trim your fenders ..... much less hassle ...
2009 JK - 2DR - 6SPD - 1/2 Doors
4.88 G2 Gears / Warn XD9000i / Custom bumpers & Swing Gate
XRC Rock Rails / 35" Kumho's on Black Rock Vipers
2.5" Mutt Lift / Rubicon T-Case / E-DISCO / VIAIR OBA
Rear CV Driveshaft / Rear Detroit Locker / Front Aussie
Teraflex Sleeves / Gussets / Nitro Chromoly Axles
dmhines is offline
post #5 of 14 Old 07-23-2010, 11:14 PM
I have a 1" daystar on mine. I trimmed the boot just because it was a little tough getting into reverse, no big deal, takes 5 minutes.
As for all saying trim the fenders, hell ya. I had to anyways because I am running a 2.5" lift with 37s and I needed to.
As for hassle, none at all. Takes about an hour and that's it. I wouldn't recommend more than an inch though, could have some troubles after that.
My sig is HUGE in Japan
Jscwerve is offline
post #6 of 14 Old 07-23-2010, 11:37 PM
planman's Avatar
On my 2 door, 6 speed, I have a 1" body lift, and I had to trim the boot. No big deal.
I ran 37s with a 2.5" lift, flat flares, and 1" body lift.
Now I run 40s with essentially a 3.5" lift, 1" body lift and flat flares.
I really like my 1" body lift because I really like the low center of gravity on big tires.
Pics with 37s and with 40s:
planman is offline
post #7 of 14 Old 07-24-2010, 04:15 PM
I have a 1" M.O.R.E body lift and I trimmed the boot. It was was an easy install, the boot trim was a piece of cake, and I have had no problems with it popping out of gear..I say go for it, it is an easy way to get a little extra tire clearance and it keeps your COG low.
07 2 Dr White Rubi, 6spd
Linexed tub
EVO Rear Bumper Fascia
Poison Spyder Boby Mounted Tire Carrier
Matercraft grab handles
M.O.R.E. 1" BL
Shrockworks midwidth w/ winch hoop / Linexed
Warn 9.5TI / Spidertrax fairlead / Viking trail line
Marathon Seat covers
PC 8179's 15x10
Toyo MT 37x14.50x15
Shrockworks sliders
EVO C2 Gussets
3.5" Rock Krawler X Factor
Coil Overs Front/rear
12" rear stretch
River Raider stretch corners
Smittybilt XRC front enders
07JKRUBI is offline
post #8 of 14 Old 07-24-2010, 04:33 PM
eggwhite93's Avatar
I know you are the man with the plan so. Do you think I can ge away with the new RK 2.5 flaties and 37s? Should I go with the body lift too? Im looking for low COG as well.
Marc
2007 2 door Rubicon ROCK KRAWLER - POYL PERFORMANCE - RIVER RAIDER - POISON SPYDER - BILSTIEN - PITBULL - ACE - SMITTYBILT - BLACK ROCK - SUPERCHIPS - SPIDERWEB SHADES
eggwhite93 is offline
post #9 of 14 Old 07-24-2010, 04:41 PM
planman's Avatar
With flat flares & a 1" body lift, you can run stock front bumpstops with 4" backspaced wheels or 1" extended bumpstops with 4.5" backspaced wheels. In the rear, you can do it with 2.5" extended bumpstops.
If you do it without the body lift, you will lose uptravel in your suspension because you will need to run taller extended bumpstops.
That is why I did the 1" body lift when I upgraded to 37s.
Sent from my Droid using Tapatalk
planman is offline
post #10 of 14 Old 07-24-2010, 08:11 PM
Zack Massey's Avatar
Personally I would not go with a body lift. From what you are saying then you could lift with a 3 1/4" Rough Country lift. You can get it for less than $400 and it will come with springs, shocks, and all hardware to get your jeep rolling right.
I have been running mine this way with 35" tires and am very happy.
Zack Massey is offline
post #11 of 14 Old 07-24-2010, 11:05 PM
MarcusRTJ's Avatar
If you're going 2.5" coils don't spend your money on the RC lift. The spacers are fine but when I go coils I'm going to RK's 2.5" kit.
The 2.5" RC springs don't give you 2.5" of lift. It is quite apparent looking at my wife's next to my spacer lifted 2 door.
08 Unlimited - Flame Red "Lucy"
2.5" RC Coils & 33" KM2 on stockers
08 JK - Stone White "The Goat"
2.5" BB, 35" MTRs on 15s, Rubi sliders - just the beginning
Keeping Austin Weird
MarcusRTJ is offline
post #12 of 14 Old 07-24-2010, 11:28 PM
planman's Avatar
What matters is bumpstop length and fender clearance, not lift height.
A 3.25" lift with 2.5" extended bumpstops will fit the same tires as a 2.5" lift with 2.5" extended bumpstops.
Especially for a 2 door, a 1" body lift with a 2.5" suspension lift is preferable to an incomplete 3.5"-4" lift.
planman is offline
post #13 of 14 Old 07-25-2010, 03:10 PM Thread Starter
Thanks for all the input!
I've already trimmed the fenders and will likely go with the 1 inch body lift as I would prefer to keep as much upward travel as possible.
If people aren't really having trouble with the 6spd and BL - other than without trimming to boot having trouble going into reverse - Seems like a good route to go
as many have said "keeps the COG low"
Any hints or anything for trimming the boot? Pictures?
JonP is offline
post #14 of 14 Old 07-25-2010, 04:48 PM
planman's Avatar
No one here has done a write-up that I have seen yet.
Here is a write-up from the internet magazine (scroll down in the write-up for the special instructions for 6 speed owners):
http://project-jk.com/jeep-jk-write-...ation-write-up
planman is offline
