Auto Won't Use 1st Gear - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 07-21-2010, 01:05 PM Thread Starter
Exclamation Auto Won't Use 1st Gear
My automatic 2-door won't use first gear at all. Starts out in 2nd, won't even go into 1st when putting the shifter down to first gear. All other gears work fine. Help?
'08 X 2-Door, 4" Pro Comp suspension lift, 35" MTR Kevlars, Warrior tube doors, MBRP exhaust kit
XC4D4MD is offline
post #2 of 3 Old 07-21-2010, 02:14 PM
SoK66's Avatar
First thing to do is check fluid level, if OK then check your cable adjustment. If all the external adjustments are OK you'll need to drop the pan and look for tell tale signs of broken, expensive pieces parts.
SoK66 is offline
post #3 of 3 Old 07-22-2010, 05:01 AM
afoulk's Avatar
Check your fluid level, though I doubt thats it. Otherwise I'd take it to the dealer. I was having the same problem every once in awhile, it wouldn't downshift into first when coming to a stop and then would pull out in second, but mine would downshift into first if I moved the shifter there. I had it at the dealer and they reflashed the module for me and it seemed to take care of it.
SOLD-08 Unlimited X, "jeep green", auto, limited slip, hushpower muffler, Aerotech Interceptor gauge,Powerstroke tranny cooler, skidrow evap skid, AFE Pro 7 filter, Teraflex leveling kit, EVO control arm skids, 15x8 Black Rock 909's, 33" KM2's
afoulk is offline
