Project: Right the First Time - Page 10 - JKowners.com : Jeep Wrangler JK Forum
 100Likes
post #226 of 302 Old 04-29-2019, 11:01 AM Thread Starter
cody48's Avatar
Hello JKowners, been a while...
Jeeps been sitting quite a bit, took up cycling and racing again at the end of 2017 and still now but since a buddy of mine, who is in a few of my build pics, finally got his own Jeep, it has triggered me to get mine back out and looking for other ways to make it better.
Will have some update pics this week.
ChuckTheRipper likes this.
cody48 is offline
post #227 of 302 Old 04-29-2019, 11:49 AM
ALASHA's Avatar
Welcome back!
I really liked this build
cody48 likes this.
ALASHA is offline
post #228 of 302 Old 04-29-2019, 02:24 PM Thread Starter
cody48's Avatar
Welcome back!
Thank you Alasha. I was reading back through the thread today and all the positive comments gave me motivation to start posting again.
cody48 is offline
post #229 of 302 Old 04-29-2019, 02:29 PM Thread Starter
cody48's Avatar
Have ya'll seen these dual rate swaybars from G2?
http://www.g2axle.com/pages/view/core_drs.php
The jeep has always been driven with only a Antirock on the front, and I was thinking I'd like to get it to drive with a bit less body roll on the highway. These G2 units are pretty new, so I couldn't find any feedback on them ANYWHERE. After studying all the other options, I went ahead and decided to be the guinea pig on this one. According to the marketing, it is like an OEM rate until you put air pressure to the center section, then it disengages the outer bar and leaves the smaller diameter inner bar to control the sway.
Box says Made in USA
It looks well built from what I can see. Hopefully the internal air coupler mechanism will work and last.
Pretty simple to bolt it on, except I needed OEM swaybar mounts and bushings that I no longer had. Ordered those from Quadratec with some poly bushings.
This swaybar also does not come with links so I am running the Antirock links temporarily.
Now I need an air supply to be able to disengage it. I've only ever had a c02 tank sitting behind the seats and don't particularly enjoy dealing with it in the way and having to get it filled, plus I use the tank around the house some, so it's not always in the jeep anyway.
All the electric compressor options that I've seen didn't look very satisfying either. Then I found some REAL onboard air! ORO kit that puts a York compressor on the front of your engine.
https://offroadonly.com/shop/on-boar...er-jk-2012-15/
Called up Marcus at River City Offroad and got this ordered. Still waiting for ORO to ship it out though.
cody48 is offline
post #230 of 302 Old 04-29-2019, 04:22 PM
Simply incredible build. Such a combination of imagination, tech knowledge, and ability. Beautiful, tidy Jeep. Thanks for sharing!
cody48 likes this.
JJS2 is offline
post #231 of 302 Old 04-29-2019, 08:03 PM
08JKUR33's Avatar
Man I have wondered about this build since I came across a picture of the rear cargo modification you made. It’s definitely a clean built Jeep!
cody48 likes this.
08 Jk Unlimited Rubicon
Link to build page-
08JKUR33 is offline
post #232 of 302 Old 04-29-2019, 11:57 PM
ChuckTheRipper's Avatar
Thanks for coming back. Builds like this keep me around. Canít believe itís been so long since youíve had it complete.
cody48 likes this.
ChuckTheRipper is offline
post #233 of 302 Old 04-30-2019, 10:46 AM Thread Starter
cody48's Avatar
Ya'll are awesome, glad to be back, thanks again!
Sooo the York compressor should be able to actuate the swaybar and inflate tires easily with no air tank, but i was think of taking advantage of the available air I would have on hand now. How about a big air horn??!! I ordered a Viair 2.5 gallon tank and then proceeded to try and figure out where i could mount it.
Going to need to move the EVAP canister out of the way. This would free up a large amount of room between the exhaust and rear drive shaft. Unfortunately the bolt-on relocation kits wouldn't work with my rear suspension
Then I found this jewel
Went to order it and when the total came out to over $400.00 for a simple bracket, I lost interest and backed out.
Started to design my own bracket similar to this one, but then I wouldn't have room to mount the air horn I had picked out, so figured out a way to get the EVAP to the rear, right behind the fuel tank, using the OEM bracket and some rivet nuts. Had to cut out the right rear spring bucket.
A few hoses and clamps and that was taken care of.
Air tank has room to be mounted, just had to cut one of it's mounts off and reweld it into a slightly different spot to get it to sit under the jeep the way I wanted. I mounted it as far backwards as I could without any exotic brackets to be able to put a drain valve on the bottom port and not have it get knocked off by a rock or something (hopefully). Made a heat shield for whatever reason out of some 0.063" aluminum to put between the tank and exahust too.
M6 Rivet nuts that fit the tanks rubber isolating mounts
I didn't bolt the tank up yet because I need to do something different with my tail pipe. You can probably see on the corner of my storage box in the last picture that the exhaust has been heating it up and also burning the powdercoat on my track bar. Guess I'm gonna put a turn-down right behind the cat since I cant find a better way out without it blowing on something else important (shocks, bumpstops, tire, brakes, etc.)
cody48 is offline
post #234 of 302 Old 04-30-2019, 10:56 AM Thread Starter
cody48's Avatar
And here is the other cool part of all this air mess
Sound clip in link below
https://hornblasters.com/products/tug-37-tug-horn
This thing is 37" long to get that deep sound!!! I didn't want to have the typical train horn sound like everyone else though...
cody48 is offline
post #235 of 302 Old 04-30-2019, 12:38 PM
ALASHA's Avatar
I have a belt driven York on mine but I also have an Oasis that I have been trying to figure out how to mount. This has given me some ideas. Thanks!
cody48 likes this.
ALASHA is offline
post #236 of 302 Old 04-30-2019, 01:54 PM Thread Starter
cody48's Avatar
Oh really? Is it someone's kit or did you fab it up yourself? How well does it work?
cody48 is offline
post #237 of 302 Old 04-30-2019, 02:44 PM
ALASHA's Avatar
I believe it was a slightly modified Kilby bracket for mounting the York and oil separator. After that, everything was just custom:
https://www.jkowners.com/forum/modif...ba-system.html
Works pretty well. Info is in the thread.
cody48 likes this.
ALASHA is offline
post #238 of 302 Old 05-01-2019, 12:54 PM
Man am I glad you bumped this thread back up. Loving the build. The Nemesis flares look great!
cody48 likes this.
2012 Ford F150 FX4 EcoBoost CCSB RaceRed
Looking for a built LJ/JKUR
TyLeRsJK is offline
post #239 of 302 Old 05-01-2019, 08:40 PM Thread Starter
cody48's Avatar
Awesome, thanks!
cody48 is offline
post #240 of 302 Old 05-01-2019, 08:41 PM Thread Starter
cody48's Avatar
Would you look at this mf'er
cody48 is offline
post #241 of 302 Old 05-01-2019, 08:43 PM Thread Starter
cody48's Avatar
Ok got a surprise done tonight. Changing the look of the Jeep quite a bit but it looks just as good as I had bet on.
Out with the Altitude edition black grill and in with the Polar edition grill!
Also installed some JL hood latches while the grill was off. That was not a direct bolt on.....had to do a lot of trimming on the JL latches to get the hood/fender line back right and also the tension on the latches just right.
rockystock likes this.
cody48 is offline
post #242 of 302 Old 05-03-2019, 03:57 PM Thread Starter
cody48's Avatar
New taillights and replaced all 96 beadlock bolts since they were rusting.
cody48 is offline
post #243 of 302 Old 05-04-2019, 09:06 PM
rockystock's Avatar
So are the slots wider on that new grille, or is it just an illusion from the black trim? Looks great!
rockystock is offline
post #244 of 302 Old 05-05-2019, 06:11 PM Thread Starter
cody48's Avatar
The slots are exactly the same. I pulled my OEM black inserts out of my original grill and popped them in this blue one. A lot of grills don't have the separate inserts so you see more of the body color.
cody48 is offline
post #245 of 302 Old 05-07-2019, 11:51 AM Thread Starter
cody48's Avatar
ORO Onboard air kit came in
cody48 is offline
post #246 of 302 Old 05-08-2019, 04:57 PM Thread Starter
cody48's Avatar
Soo.......this happened today
jvandy50 likes this.
cody48 is offline
post #247 of 302 Old 05-08-2019, 05:03 PM
Well that escalated quickly
cody48 likes this.
2012 JKUS - Ripp SC - 4" TeraFlex - 37x12.50r17 TR HD17s - UD60s w/ ARBs
AEV Bumper - RR Sliders - TF Hinge - RockHard Skids
bigjimbo is offline
post #248 of 302 Old 05-09-2019, 07:42 AM
ALASHA's Avatar
Pretty sure the ORO kit isnt compatible
cody48 likes this.
ALASHA is offline
post #249 of 302 Old 05-09-2019, 10:52 AM
08JKUR33's Avatar
Hmm well ya that makes sense, get an ORI onboard air kit then I guess a new motor would be next. For easy install and all lol. Hell ya
cody48 likes this.
Link to build page-
08JKUR33 is offline
post #250 of 302 Old 05-09-2019, 12:48 PM
L86 or L83?
Details! What year, what transmission?
What’s the installation plan?
Conquistador is offline
