For those thinking about "bed lining" your front grill - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 07-17-2010, 02:41 PM Thread Starter
Ron R's Avatar
Shot mine yesterday using the Duplicolor truck bed liner in the spray can you can get from any auto parts store for $8-$10. Surprisingly, it's a near-perfect match in color and texture to the factory fenders and (in my case) the Fab Fours bumper.
The grill comes off real easy without any tools - pop the lock tabs at the top, slide it out the bottom, and turn the turn signal lamps to remove the light bulbs (they'll stay attached to the Jeep). Once they're out you can remove the whole grill and there are two tabs you squeeze from the back to remove the shell of the yellow lights from the grill. I spent a 40 minutes prepping the surface, sanding it with 120 paper first, then 320, then cleaning it all up real good. Taped over the rubber strip on the top, sprayed an adhesion promoter over the whole surface first and let it get tacky, then sprayed the bed liner. I did 3 coats, about 6 minutes apart. You can go thicker if you want but I wanted to keep it a little light so some flexibility was retained. After about 20 minutes in the Florida sun I put it back on the Jeep.
Pretty happy with the way it came out. On my TJ it held up pretty well, the couple of times where tree branches scratched some off I just cleaned it and resprayed on top of it. But that was a metal grill, so we'll see how it holds up on plastic like this... I figured for $10 if it doesn't last I can always sand it back off and take the thing to the Line-X shop.
Ron R is offline
post #2 of 13 Old 07-17-2010, 02:46 PM
JDodge's Avatar
Was wondering how it would look on black.....now you got me wanting to do it. Looks real good
JDodge is offline
post #3 of 13 Old 07-17-2010, 02:47 PM Thread Starter
Ron R's Avatar
At $10, it's the cheapest mod I've done so far. If you're going to do it, definitely remove the grill from the Jeep, don't just tape it off & shoot. It will take less time to remove it than tape anyway, and when you're spraying you can coat it from all angles to keep it nice and even and won't miss anything.
Ron R is offline
post #4 of 13 Old 07-17-2010, 03:30 PM
That looks pretty sweet.
Black here too, and I was worried that there wouldn't be enough contrast to make it really stand out. 'n
p.s. Where did your winch go?
Fnord5 is offline
post #5 of 13 Old 07-17-2010, 03:42 PM
looks good on the black, think about tinting the ambers?
post #6 of 13 Old 07-17-2010, 04:05 PM
You should use the smaller lights in the bumper to replace the ambers, then do this with them:
Fnord5 is offline
post #7 of 13 Old 07-17-2010, 05:45 PM Thread Starter
Ron R's Avatar
Holding out for the smittybilt xrc 10, they're out of stock until October. 10k winch with onboard air and 2.5 gal tank for $600 at summit.
Ron R is offline
post #8 of 13 Old 07-17-2010, 05:48 PM Thread Starter
Ron R's Avatar
I wasn't, but dammit I am now
Ron R is offline
post #9 of 13 Old 07-17-2010, 05:56 PM
it's subtle, but made a huge difference on mine. I kinda have the whole black and white thing..AMBER didn't fit at all. Looks much cleaner up front
post #10 of 13 Old 07-17-2010, 06:27 PM
mb817's Avatar
looks good.
mb817 is offline
post #11 of 13 Old 07-17-2010, 10:48 PM
PO'BOY's Avatar
how much area does one can cover? would it be cost effective to use that to spray the interior tub versus another brand? opinions?
PO'BOY is offline
post #12 of 13 Old 07-18-2010, 07:18 AM Thread Starter
Ron R's Avatar
It took almost the full can to do the front grill. I wouldn't use it on the tub personally, I just don't see it holding up to constant rubbing. On the other hand, if it did rub off in any areas it's cheap to fix, heh. Something like Herculiner or one of the other roll-on products if you aren't doing a professional spray would be better there. It would take too many coats of this stuff for it to hold up.
Ron R is offline
post #13 of 13 Old 07-18-2010, 08:49 AM
Trail Concepts Hmfic
jdemonto's Avatar
Looks great!
Jason
602-314-5356 or
jdemonto is offline
