Page 1 of 2 | 1 | 2 |
Gas Mileage w/lift & 35's
I'm not normally one who cares about gas mileage but in the 25 miles I've put on the Jeep since doing a 4" lift and 35's (Baja MTZ's) I've already used nearly a quarter tank of gas. The thing is, I know that "25 miles" isn't exactly accurate since I haven't adjusted the computer for the new tires, but still, it just seems to be burning fuel a LOT more than I expected it to.
I'm ordering the AEV tuner today so I can adjust for tire size and turn off the pesky tire pressure indicator so I'll have an accurate mileage reading. My question is, what can I do next to get back some of those lost MPG's? Just gears? Everyone has suggested I go to 5.13's, will that actually improve mileage over the 3.whatever's that are in there now?
Sponsored Links | |||
Advertisement |
5.13 will give you more power not more MPG. If anything you might see less MPG.
What is your current MPG?
Stick or auto?
I driver around 44miles each day to and from work. I average 17 MPG.
Stick or auto?
Originally Posted by StubEXrube
View Post
I drive about 45 miles per day to and from work and I get 11.5-12.5 mpg. Thats with 37's and 5.13 gears. I am a bit heavy on the gas I guess. F it
Advertisement |
I average 16-18mpg on 35s, you need to figure out what gear ratio you have in yours. And please do an accurate mpg test...
I too average 16-18 mpg with 35's and the stock 4.10's. I did reprogram with SuperChips and run Performance 91 with High Octane gas. My ride is a DD with about 120 miles a day commute. Once you adjust your speedo and run a few tanks through it you should get a better feeling of the gas mileage. You still need to find out what ratio you have.
2008 JK 4 Door Rubi, 37's and stuff...
Originally Posted by ExWrench
View Post
3.73 gears, I just ordered the AEV ProCal will recalibrate speedo & see how we're doing from there.
I've got 4.10's, auto, 4dr, and 32.5" (actual measured height) tires. I get 15 to 16 highway and 10 to 12 city. I'm also super heavy on the skinny pedal.
Feedback: 12 reviews
3.5" lift and 35" MT Bajas with 5.13 gears = 16.5 mpg
My Build Thread ~
NE Trail Ride Thread ~
Adrenaline Offroad ~ Best Jeep shop in the Washington DC area!![/COLOR]
Got an 07 Rubi 37 in tires 410 gears Super Chip milage program reset dash and run to the shore F around all day and head home and end up around 18mpg have to do the math and see whats up.
35's and 5.13's. I'm in the 16 range on a cool day. AC on around 12 if I'm lucky. Doors off AC off 19 mpg. Seems like every time I add something to the jeep mpg gets lower and lower. I did own a H2 before the jk and only got 9 to 11 mpg so I'm kinda use to bad mpg.
I get 14-16 on 35's but I have 4.10's and a 6-Speed...
09 2dr Blk Rubicon
Fully Built D44
RK X Factor Plus 3.5" Mid Arm
LoD Bumpers
35" Toyos
Warn 9.5ti
Everything you do will reduce the economy. The lift produces more dirty air under the Jeep. 35" tires are heavier and the rolling resistance is higher and 513 gears will take another 10% off your mpgs. If you started near 19 mpg when stock, you will lose 3-4 mpg and with a heavy foot 5-6. figure a 20-25% drop and you'll be close. But, Hey, it's a Jeep.
I'm seeing about 12-12.5mpg right now with the A/C on. That's with 35s, stock 4.10s, auto trans, and a good amount of aftermarket steel tacked on. I've got the Superchips Flashpaq but haven't tried any of the tunes yet - only corrected my speedo/odo. My commute is a whole whopping 14 miles round trip though, through residential areas (speed limit never gets above 40mph) with one school zone and 8 stop lights. And I'm easy on the gas too.
Jason West -
'16 JKUR HardRock, Granite Crystal, RE/Synergy 3.5", 37s, the new project
'09 JKUR, RE 3.5", 37" MT/R-Ks, Expedition One bumpers, TNT Customs armor. SOLD.
'95 XJ lifted and locked on 35s.
about 16.5-17 with 1 inch lift and 35's (unlimited hardtop). 4.10 auto, aftermarket front bumper, fullsize spare
I get 13l/100km. canadian gallon is 4.5l, 100km is 62miles, equates to approx. 20.66m/gal.
35" baja claws and 4:10's in an unlimited ruby on the hiway at around 65MPH in 6th, In town I get a bit better around 12.3l/100km if I go easy and use 5th alot. Had 600lbs of thinset cement riding on board for the week and milegae didn't get any worse.
I get 13l/100km. canadian gallon is 4.5l, 100km is 62miles, equates to approx. 20.66m/gal. on my side of the river. 18.12mpg on U.S. side.
35's with 5:13 auto average 13 - 14 mpg. I like the feel of the 5:13 but im pretty sure 4:88's would have netted better economy, just not sure how much better
its a jeep, its shaped like a brick, want good gas milage buy a honda
im sitting at around 12-14 with 35 and 4:10 but with the wind and the hills around here 6th gear is about useless especially topless.
Chris
'09 Rubicon 2dr, Silver
I'm getting about 15 with 35s and 5.13 gears in a stick right now. I also have a heavy foot.
I get 16-17 on the freeway with the 33's and 3.73 gears in auto.
2008 Unlimited, 2" Basic lift from Rusty's, JK quick disconnects,
Firestone MT 285 75 16 mounted to
Cragar Soft 8's 16x8 w/5" backspacing
approximately 15.5 to 16 with auto 3.5 lift 4.10 gears and 35 in tires(they measure about 34 or a little under) and have used the AEV ProCal to adjust for tire size and all that. Now if I drive harder or heavier footed then I'm down aroun 12 to 13 range but if I keep in mind how I accelerate and what not then I'm getting the higher 15 to 16 range. That's using 89 octane and for the most part level ground(bout all we have in North Dakota). When I used 90 octane or above I felt I gained a little mpg's but nothing that would make up for the price difference.
2007 JK Unlimited Sahara, Blacked Out
3.5 inch lift sitting on 35's
Poly Performance/Synergy Suspension Ball Joints
Smittybilt Oversized Tire Carrier
i get anywhere from 14-16 mpg average depending on how much city driving i do. also, with the superchip recalibration the mpg reading from the dash is within .2 mpg's of accuracy in my experience.
Teraflex - Poly Performance - Poison Spyder - Off Road Hero's - Rugged Ridge - Superchips - Goodyear - aFe
Advertisement |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
