Rugged Ridge tire carrier linkage - JKowners.com : Jeep Wrangler JK Forum
post #1 of 21 Old 07-11-2010, 05:18 PM Thread Starter
vwang's Avatar
Anyone heard of these or had a chance to try it out?
It looks like the same thing as the couple other one-motion swing out tire carriers, but curious as to how well it works.
http://www.ruggedridgeoffroad.com/je...hd-bumpers.php
at bottom of page
vwang is offline
post #2 of 21 Old 07-12-2010, 06:04 AM
tulsarob's Avatar
Wonder how well it works when you slam the tail gate shut?
tulsarob is offline
post #3 of 21 Old 07-12-2010, 06:27 AM
R0ck's Avatar
I haven't found anyone stocking it for sale yet but I plan to try it out with my RR rear bumper/carrier setup once they are available.
2007 JK Unlimited Steel Blue
For all your days prepare and meet them ever alike
R0ck is offline
post #4 of 21 Old 07-12-2010, 07:23 AM
Great but you have to adjust it correctly. That part we have to leave up to you guys.
Use the production sample every day on our test JK. When you close the tailgate, and have the link adjusted correctly, the carrier is just at the point you open the latch and lock into place.
We are shooting for the first week of August.
Rugged_Ridge is offline
post #5 of 21 Old 07-12-2010, 08:11 AM
usmcdoc14's Avatar
let us know when its ready, sometimes a product is cheaper than trying to figure it out ourselves
usmcdoc14 is offline
post #6 of 21 Old 07-12-2010, 09:13 AM
It's possible that it will work with other manufactures carriers. Sorry to say we have not tested that.
The link has an adjuster tube to allow you to set the length correctly. To long and it will want to push to hard on the tailgate. To short and it will not allow the carrier latch to be locked down. It's not a hard task just need to find the correct setting for each set-up. When the sweet spot is found you lock the adjuster in place with lock nuts.
I will try to get the instructions postedn up soon.
post #7 of 21 Old 07-12-2010, 11:50 PM
DTJK's Avatar
so are these available yet, and how much? I want one for my RR carrier, I'm so tired of the 2 handed operation, I have to drop whatever's in my hands to close the damn thing.
DTJK is offline
post #8 of 21 Old 07-13-2010, 07:02 AM
Looking at the first week of August.
post #9 of 21 Old 07-13-2010, 05:10 PM
Would this be strong enough to use without any latch?
bluejk09 is offline
post #10 of 21 Old 07-13-2010, 10:24 PM
DTJK's Avatar
Yeah, as is, my carrier sags on the latch side about 1/4" when opened. how would this work with the linkage? it would put a lot of down force on the tailgate, wouldn't it?
And what is going to replace the latch handle? Does it come with plugs for the holes if the latch is removed?
Just reread your earlier post, looks like the latch stays?
DTJK is offline
post #11 of 21 Old 07-14-2010, 07:04 AM
Yes, the latch stays. Send me some images of the sag you note.
The link uses Heim Joints (Rose Joints) at both ends. This compensates for misalignment (up or down) and removes the stress you are worried about. The sag would have to be extreme for this to be a problem.
post #12 of 21 Old 07-14-2010, 12:38 PM
So if someone was building their own custom bumper and wanted to incorporate this into their build, would you think that it would be strong enough to be used without a latch, similar to the other single action rear tire acrriers out there?
Also, I know it's not available yet, but do you have a price yet
bluejk09 is offline
post #13 of 21 Old 07-14-2010, 02:19 PM
MSRP will be around $50
I don't think this would work for your design. Because the link is almost horizontal to the tailgate (when closed) you will still have some movement outward of the carrier (not a lot but still some). Your design would need to be shorter and made custom to your carriers swing movement. Our design is driven by the way our carrier moves. I would also use two heim joint links for added rigidity. If you’re going to build your own carrier fabing your own links will be easier than adapting our part.
Regarding strength, the type of mounting bracket you build for the tailgate and the grade hardware that you use would be the limiting factors. Tire size also comes into play. That is a lot of added stress your going to be putting on the thin sheet metal of the tailgate. I would suggest using all the OE tire carrier mounting holes to help spread the load out as much as possible.
Our link is used only to push a suspended load and does not handle any retaining load. Also we keep the latch mounted to the bumper to isolate the carrier from the tub (body). You would be amazed by the amount of movement of the frame to body on a 4 door JK.
Your design would require a bit more interaction of these to isolated parts. Our link has no stress on it when closed and allows this movement to take place freely.
post #14 of 21 Old 07-15-2010, 12:26 PM
DTJK's Avatar
I have no idea how to post pics on these forums. can I email you a pic?
Thanks.
DTJK is offline
post #15 of 21 Old 07-15-2010, 12:51 PM
Thanks.
Send me a PM and I'll give you my e-mail address...
post #16 of 21 Old 08-01-2010, 11:15 PM Thread Starter
vwang's Avatar
anyone mounted one of these on their jeep yet?
Teraflex - Poly Performance - Poison Spyder - Off Road Hero's - Rugged Ridge - Superchips - Goodyear - aFe
vwang is offline
post #17 of 21 Old 08-02-2010, 07:39 AM
Yeah x2, I want to know if it will work with my Shrockworks rear with tire carrier.
2008 JK 4Dr Rubicon
Stone white
Mygig W/Uconnect working.
Hard top/Auto tranny
First mod, dog slobber.
Painted hard top
Spidertraxx 1.5 spacers
Teraflex 3" lift
rob4607 is offline
post #18 of 21 Old 08-02-2010, 01:23 PM
These should be shipping by the end of this week....
post #19 of 21 Old 11-21-2010, 09:27 AM
Has anyone tested them with a different manufacturer's tire carrier?
vinnysucks is offline
post #20 of 21 Old 05-22-2012, 03:20 PM
Riptyd's Avatar
Send a message via Yahoo to Riptyd
If ya want to send me one to put on my smittybilt SRC with tire carrier I'd be willing to do a full review with pictures of the instalation... Let me know
Riptyd
“Adventure is worthwhile.”........Aristotle
Yellow 4dr.,
Wildboar Safari Rack
Midland 75-822 CB Radio(Ch4or16)
Smittybilt SRC front Bumper, Rear Bumper/Tire Carrier
Smittybilt SRC Side Armor
KC Daylighters
JKS ACOS adjustable coil spacers
Procomp shocks
SpyderTrax Wheel Spacers
BFGoodrich Radial AT 285/70/17
More mods on the way.
JEEPERS should always be on CB Cannel 4 or 16
Riptyd is offline
post #21 of 21 Old 04-12-2013, 10:40 PM
So why was the verdict on these? I just installed the xhd bumper and was thinking about the carrier but I access the rear gate a lot so it needs to be super easy.
TechLife is offline
