Rock krawler jam nuts not making full contact - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 07-09-2010, 06:15 AM Thread Starter
RUDY850's Avatar
Anyone else notice this on there Rock krawler stuff
Put lower control arms on a week ago and had to file the arms square to get the jam nuts to come in full contact with the arms when tight. They had a 35 thousand gap most of the way around under the jam nut
just got my upper arms and track bar and there the same. the track bar looks to have even a larger gap at the one end
RK 3.5 LIFT/RRD SHOCKS/FRONT CONTROL ARMS/DRAG LINK/TRACK BAR/REAR BRAKE HOSES/COOPER 295-75-17 STT JEEPERMAN FRONT BUMPER SUPERWINCH EPI9 JKS LOWER TRACK BAR BRACES/DISCONNECTS CRAGAR WHEELS SOFT 8 SYNERGY UPPER TRACK BAR BRACES RR SKID PLATES BENCHMARK DESIGNS EVAP SKID
RUDY850 is offline
post #2 of 14 Old 07-09-2010, 07:34 AM
usmcdoc14's Avatar
never looked, to be honest I never cared its a jam nut, its still doing its job.
usmcdoc14 is offline
post #3 of 14 Old 07-09-2010, 08:22 AM
Sir
Please give the office a call and we can help you out.
How tight are you getting the jam nuts? There could be a ton of powder coat on the arms. We have been working with some new powder coat in house that has a crazy finish.
Rock Krawler
post #4 of 14 Old 07-09-2010, 09:24 AM
ICTHRUU's Avatar
can't say i ever looked. i just tightened the hell out of them and they haven't budged
ICTHRUU is offline
post #5 of 14 Old 07-09-2010, 10:54 AM
usmcdoc14's Avatar
Originally Posted by Rock Krawler Suspension View Post
Sir
Rock Krawler
in an honest question: Besides the main reason for jam nuts is there any structual need or perk to them having "full" contact with the surface they are jammed against ?
post #6 of 14 Old 07-09-2010, 04:16 PM
Broncojohn's Avatar
Yes. The jam nut is used to preload the threads of the rod end/ tube union. If the jam nut is not flat the load will be uneven. The preload is needed to prevent wear and thread failure. It may not be as critical with our big boy shit, but this is what is preached in the aviation world.
Broncojohn is offline
post #7 of 14 Old 07-09-2010, 06:27 PM Thread Starter
RUDY850's Avatar
Sir
Rock Krawler
I called and talked to someone before. After I noticed this on my lower arms
Was told this was a first of hearing about anything like this.So I figured ok stuff happens
was offered to return them but I just asked if it would be ok to grind or file them down first to see if that would work. was told ok and if that didn't work to call back
Jam nuts were tightened down very tight
I thought it could be the powder coat at first also but its not
Just wanted to find out how others were dealing with this and if they noticed this also.
Side note
I love how heavy duty the parts are
Some pics of what I did to get the lowers square
RUDY850 is offline
post #8 of 14 Old 07-10-2010, 06:32 PM
ICTHRUU's Avatar
by the way, crawled under to give mine another look and the are flush.
ICTHRUU is offline
post #9 of 14 Old 07-10-2010, 07:48 PM
Way over analyzed issue. we have been installing rockKrawler products for just over 7 years now, and yes, some of the arms have this "issue" but, If the Jam nut is tightened correctly with a few drops of red Loctite, you will never have an issue with it. Also, remember that, as a part of mechanical preserverence, you will need to periodicly check the tightness of EVERY suspension compnent. It is the end users responsibility to check the tightness of anything suspension related after a hard wheeling session.
Joe
Absolute Offroad
Absolute Offroad is offline
post #10 of 14 Old 07-12-2010, 09:53 AM
Engineering just gave us the specs on the cuts on the end of the bar and they are to be within .020 or 20 thousands perpendicularity to the axis of the bar!
Rock Krawler
post #11 of 14 Old 07-12-2010, 09:58 AM
Heat'n and a beat'n...
STUPIDFACE's Avatar
Joe
Absolute Offroad
No doubt. My tape measure only goes down to 1/16".
corey d
corey d
2008 JEEP...
STUPIDFACE is offline
post #12 of 14 Old 07-12-2010, 10:48 AM
WOW. You done gots you one of dem new fangled measurin sticks huh??
post #13 of 14 Old 07-12-2010, 03:13 PM
Broncojohn's Avatar
With .020 tolerance and the usual tolerances dealing with threads, this would mean .020 feeler guage will fit untorqued, but under torque the jamnut will be flush all the way around.
post #14 of 14 Old 07-12-2010, 03:35 PM
STUPIDFACE's Avatar
Yeehaw, it even sucks inside of a shiny box when not measuring.
corey d
corey d
2008 JEEP...
