Urgent body lift help needed - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 07-08-2010, 10:14 AM Thread Starter
LaxinFish29's Avatar
This is my first new thread asking for help but I need it bad. Im installing a PA 2" body lift. Everything was going fine until I got to the front core stock bushing. For the PA kit you are supposed to hammer out thse two bolts on the side.
Its pictured in step 21 at this link. http://project-jk.com/jeep-jk-write-...ation-write-up
Went over to the vice, took said hammer, and nothing. Tried a little harder while still under control and it started to bend the "wings" on the core support rather than extracting the bolts. PLEASE HELP! I have tried PB by the way.
2007 Sahara Unlimited. Zone 3" lift. JKS adjustable front track bar, Fox steering stabalizer, Crown kevlar brake lines, MBRP grill guard w/PIAAs. pistol grip Hurst shifter. Spiderweb sun shade. Homemade "raingler" style rear and side nets. Flowmaster Super 40. Stock 17" wheels. 35" Nitto Trail Grapplers. DVD/Nav head unit. MBRP stubby w/ mm winch. PJ stubby rear.
LaxinFish29 is offline
post #2 of 8 Old 07-08-2010, 11:02 AM Thread Starter
22 views, someone please help me out
post #3 of 8 Old 07-08-2010, 11:07 AM
bodybrdng's Avatar
Try using a flat head screw drive in the side as a wedge and go around the whole side. Have any liquid wrench or WD40? Might just have gunk pushed in there jamming it
bodybrdng is offline
post #4 of 8 Old 07-08-2010, 11:09 AM
venom's Avatar
have you tried using a piece of pipe or even a big enough socket to fit over the whole bolt head and sandwiching the whole thing in the vice and cranking the vice to press the bolt out instead of hammering it?
that way you push straight and are supporting the area around the bolt head with the pipe/socket
Originally Posted by My Wife
venom is offline
post #5 of 8 Old 07-08-2010, 11:57 AM
support the wings while you hammer out the bolt. I bent my wings a bit but they straighen out when bolting up just keep whakin those bolts
37" Pitbull Rockers on 15x8 Daytonas
BDS 4.5" Long Arm Lift
PA 2" body lift
XRC Stinger with a Warn M8000
EVO C2 Gussets
Selectable locker mod
Teraflex S/T System
john smack is offline
post #6 of 8 Old 07-08-2010, 03:29 PM Thread Starter
Neither screwdriver nor pb worked.
Its a round head
Interesteing. Im not a small dude and I have them some good licks.
Thanks for the help! Everything went back in the box and the jeep is back together until I figure something out. Got the new rims and tires on so thats good enough for now.
post #7 of 8 Old 07-08-2010, 03:48 PM
neoxxis's Avatar
I installed mine (P.A. 2") without any problem...
Used the bench vise and hammered them out...
Just hit hard, straight, with good support for the oem wings...
Good luck!
neoxxis is offline
post #8 of 8 Old 07-08-2010, 04:01 PM
gold knight's Avatar
Originally Posted by LaxinFish29 View Post
...Its a round head.....
Even better. Like Venom said, use a pipe or socket that is a little bigger than the head and long enough for the bolt to slide into it. Then use the vice as a press to force the bolt back into the socket.
Good luck.
gold knight is offline
