Unavailable options for axles? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 22 Old 07-06-2010, 02:20 PM Thread Starter
Dynatrac's Avatar
We've had the ProRock 44 out for a while now and we're currently checking into building a new 'standard' version that would address the caster issues JK owners face with a lifted rig. So aside from that......
Are there options or features you'd like but can't currently get on a PR44 or 60? Front or rear? Are there options out there you want but NOBODY builds? The JK world is moving very fast and the aftermarket still has some catching up to do. What could we build that would well suit the JK owner that isn't currently considered?
Dynatrac is offline
post #2 of 22 Old 07-06-2010, 02:34 PM
Weld a trackbar bracket on the front with multiple holes like the one Poly Performance has out. That way if you're going the high steer route it's there, if not you trim it down if you're worried about it hitting the frame.
Alaska-HWY JK is offline
post #3 of 22 Old 07-06-2010, 02:54 PM
I second the front trackbar mount. I have the ProRock and I had to fab up my own bracket because nothing aftermarket fits the ProRock housing. Those of us who want to run high steer knuckles, etc. are left trying to figure it out on our own. Multiple mounting holes for the front trackbar would be awesome!
jdahlum is offline
post #4 of 22 Old 07-06-2010, 03:47 PM
Poly makes one for the 3" axle tubes. Thats what I have on mine.
post #5 of 22 Old 07-06-2010, 04:02 PM
desert dog's Avatar
Place the lower shock mounts more toward the ends of the axles so the shocks will not hit the frame during full droop on a lifted rig. I have seen a couple of Pro Rocks where the owners had to buy the Poly relocation mounts.
desert dog is offline
post #6 of 22 Old 07-06-2010, 04:22 PM Thread Starter
Dynatrac's Avatar
Good ideas!!! Keep 'em coming.
Dynatrac is offline
post #7 of 22 Old 07-06-2010, 05:25 PM
andrelopez99's Avatar
Coil over brackets w/ no spring pads, some sort of bump stop
Joint on the upper arm mounts - rebuildable
andrelopez99 is offline
post #8 of 22 Old 07-06-2010, 07:47 PM
d'sjk's Avatar
I would love better ground clearence with use of 35inch tires and a slightly cheeper price as long as you can still make everything in the USA
Axles are on my list but a bit far down for now....Well unless I hit the lotto or get a big raise at work.
d'sjk is offline
post #9 of 22 Old 07-06-2010, 08:21 PM
Tony23's Avatar
Both of these I asked for when I purchased my prorock but was told that it would cost too much to do and was not going to be offered.
How about a trade-in program.
I also think you should ship them with out ball joints and lower the price. My joints lasted about 500 miles before the prosteers went in.
Tony23 is offline
post #10 of 22 Old 07-06-2010, 11:41 PM
Dana 70 Full Float rear that will accept the stock brakes
*jrwiii* is offline
post #11 of 22 Old 07-07-2010, 05:51 AM
usmcdoc14's Avatar
Wilwood brake setup using 5on5 bolt pattern (easy and cheaper than the "big brake shit" or SRT stuff seeing as you can already get hats in 5on5) and the same for rear with either a spot caliper or other e-brake.
Or just sell the bracketry and custom hardware with instructions like "use willwood dynalite caliper and rotor part # xxxxxxx"
Full float 60 rear, 35 spline or larger, 5 on 5 bolt pattern
usmcdoc14 is offline
post #12 of 22 Old 07-07-2010, 03:22 PM
BADGER's Avatar
By far the two most important items here, IMO, are the front track bar mount and outboard shock mounting.
-Milton Friedman
BADGER is offline
post #13 of 22 Old 07-07-2010, 06:04 PM
Living Still's Avatar
I second the full float option although I have a feeling that you would probably provide that if someone called you up and asked for it. Maybe it would be cheaper if it wasn't a custom quote though? Kingpin knuckle options would be nice too, but to my knowledge you guys have never done those. The solution to that in my mind is to order a bare housing with tubes and brackets then weld on the Cs and king pin knuckles. It would be easier if you guys offered those things boxed up and ready to go. For the majority of users full float and kingpins might be overkill and much more costly though. With all of this it would probably stress your ability to mass produce boxed ready to go axle sets so I do not expect it to ever happen.... but still !
~Casey
Living Still is offline
post #14 of 22 Old 07-08-2010, 12:02 AM
Portals..... and diff that will bolt into a rhd model
DaveJK is offline
post #15 of 22 Old 07-19-2010, 11:03 AM Thread Starter
Dynatrac's Avatar
~Casey
You're right, we already have a full float option. This option is becoming more popular for a heavy JK. We offer kingpin 60's for the users that prefer them to a ball joint 60.
Dynatrac is offline
post #16 of 22 Old 07-19-2010, 11:25 AM Thread Starter
Dynatrac's Avatar
A locking hub option has been requested for the 5 on 5 pattern. If you have any experience with the Warn kit that was sold for the TJ, will that small hub design suit your needs?
SpynTec is making a 5 on 5.5" kit for the JK now, is this $1,450 option cost acceptable if you had a 5 on 5 pattern?
Dynatrac is offline
post #17 of 22 Old 07-19-2010, 11:57 AM
Prope's Avatar
Nope, breaking those hubs every trip couple trips out was a PITA!
'08 Unlimited Sahara - Hemi -
Fenders & Rockers -
Prope is offline
post #18 of 22 Old 07-23-2010, 01:12 PM
I just got my prorock 44 last night, I will be installing it on Sat, I am using AEV 3.5 9th degree suspension, I know AEv has order from dynatrac, does the relocation bracket bolt to prorock44, and do I need to make a new bracket
ericdoesitbetter is offline
post #19 of 22 Old 07-23-2010, 01:17 PM
One thing I've already noticed. I have JKS Swaybar quick disconnects and on the passenger side it is a royal PITA to get the bottom end of the link off. The brackets are all in the way. Don't know if there is anyway to make it work better without really weakening the bracket though.
2007 Rescue Green 2-door
A few mods here and there
jgkjeep is offline
post #20 of 22 Old 07-23-2010, 03:54 PM
I believe the AEV bracket mounts similar to our bracket. It uses a U-bolt to clamp to the housing. If I'm wrong please correct me, but I think removing the Dynatrac bracket & welding on something like this would work better with the flipped draglink:
LINK
It welds to the 3" tube & moves the location of the track bar up 3".
Thean Bellocchi
Poly Performance Inc.
Sales & Tech Support
805-783-2060 Ext. 200
crusty1007 is offline
post #21 of 22 Old 07-23-2010, 07:41 PM
Another thing I noticed this evening.
There isn't a drain plug on the diff.
I know that is a minor thing but the stocker had one and it is so convenient. I doubt it takes a whole bunch of extra time to machine one.
jgkjeep is offline
post #22 of 22 Old 07-24-2010, 05:38 AM
adjustable track bar mount, out-boarded shock location, coil-over mounts/bump pads instead of lower spring mounts, rebuildable upper joints, brake kit---all already addressed and concurr.
additional;
Different cover bolts/design (really like PSC one with sunken heads)--mangled the ones on my TJ and the stars sux
Hydraulic steering assist bracket...somewhere (cover?)
Engrave/mark caster grid (+/-X degrees) on axle/include degree gauge for adjustments and ease of install
Engrave your logo on the diff instead of glueing it (I know, petty, but I lost it somewhere and I'm sure that was a $50 item...lol!)
-Chris
FMCTJ is offline
