Whats the best way to tighten up my steering - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 07-04-2010, 09:42 AM Thread Starter
Butler20's Avatar
I have a 3.5 inch lift with 35s. Whenever i go over a bump over 50mph i basically lose control. I do have the stock steering stabilizer, if i get a better once such as the bilstein 5100 will this solve my problem?
3.5" Rubicon Express lift
Bilstein 5100 Shocks
17x9 Mickey Thompson Classic II
35" Nitto Mud Grapplers
Smittybilt XRC Rear Bumper
Flowmaster 40 Series
48" Hi-Lift Jack
KC Slimlights long range
Rugged Ridge mirror relocation brackets
MasterCraft Grab Handles
Butler20 is offline
post #2 of 9 Old 07-04-2010, 09:59 AM
StubEXrube's Avatar
No. Your steering stabilizer is not the issue. You need to check your front track-bar and torque it down to 125-130 ft lbs. Also check to make sure your lower control arms are torqued to manuf specs. While you're at it make sure your wheel lugs are tight (95 lbs) and that your drag-link and tie-rod are tight/ torqued to spec. Pretty sure it's your track-bar.
StubEXrube is offline
post #3 of 9 Old 07-04-2010, 11:57 AM
planman's Avatar
It sounds like something is loose or broken.
Read this thread 1st:
https://www.jkowners.com/forum/showthread.php?t=30723
planman is offline
post #4 of 9 Old 07-04-2010, 12:11 PM
MaloCS's Avatar
Some things to consider that will more then likely help with your issues:
  1. An adjustable track bar or better yet, a bracket that raises the track bar mounting location from the axle.
  2. A steering flip kit that positions the steering linkage more parallel to the ground.
  3. Getting your front lower control arms as neutral in angle as possible. The more parallel to the ground the better.
The above will go a long way in reducing if not eliminating your problems. Of course, checking to make sure all of your components are tight might help as well.
Good luck.
Those that the beast is looking for...
Listen in awe and you will hear him...
BARK AT THE MOON!
MaloCS is offline
post #5 of 9 Old 07-04-2010, 03:48 PM Thread Starter
Butler20's Avatar
Good luck.
Well i have number 1. i hae the BDS kit..
48" Hi-Lift Jack
Butler20 is offline
post #6 of 9 Old 07-07-2010, 07:23 AM
2k2wranglerx's Avatar
But it still came with a bracket didn't it? They are known for the trackbar hole egging out.
2k2wranglerx is offline
post #7 of 9 Old 07-07-2010, 03:19 PM Thread Starter
Butler20's Avatar
Yes i got the bracket...didnt know they were known for that...dang
48" Hi-Lift Jack
Butler20 is offline
post #8 of 9 Old 07-07-2010, 04:10 PM
eggwhite93's Avatar
Originally Posted by TXROCK View Post
Another option is some have bought the rough country dual steering stabilizers...not sure how well they work but could ask around. I am sure someone has advice on it!
Its the best because it looks cool!
Marc
2007 2 door Rubicon ROCK KRAWLER - POYL PERFORMANCE - RIVER RAIDER - POISON SPYDER - BILSTIEN - PITBULL - ACE - SMITTYBILT - BLACK ROCK - SUPERCHIPS - SPIDERWEB SHADES
eggwhite93 is offline
post #9 of 9 Old 07-07-2010, 05:38 PM
bubba2u's Avatar
that solved my 'wander' and i toed in the front tires about a 1/8".
bubba2u is offline
