Rear Caster...whate setting? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 06-29-2010, 11:21 PM Thread Starter
medcop's Avatar
Using rear adjustable control arms what setting / measurements should I attempt or be looking for?
Using RC 4" springs with 3/4" pucks above springs in rear and Rock Krawler spring perch wedge adjustjusts, Using a 1 3/4" puck up front above the 4" spring (had to do this to get it to level out. JKS track bars front and rear, RC adjustable control arms.
BTW.... 4 door automatic on 35's.
Enjoying life!
medcop is offline
post #2 of 6 Old 06-29-2010, 11:38 PM
sickchilly's Avatar
Send a message via AIM to sickchilly Send a message via Skype™ to sickchilly
There is no rear "caster" as the wheels do not steer. What you're adjusting is wheelbase (with the lower arms) and pinion angle (with the upper arms). Set the rear arms so your axle is centered in the wheel well. Then set your pinion angle as appropriate for your drive shaft.
2007 Jeep Green Rubicon 4-door with various bits 'n pieces... broken in but not even finished!
sickchilly is offline
post #3 of 6 Old 06-30-2010, 07:50 AM
2k2wranglerx's Avatar
yup, set the lowers so it's centered, set the uppers so your pinion angle is correct.
boom done.
2k2wranglerx is offline
post #4 of 6 Old 06-30-2010, 08:08 AM
JKSteve's Avatar
Don't you want the wheel centered when its stuffed, not static?
LJ Rubicon
JKSteve is offline
post #5 of 6 Old 06-30-2010, 08:13 AM
riverzendz's Avatar
boom done.
Yep, what they said.
riverzendz is offline
post #6 of 6 Old 06-30-2010, 08:56 AM Thread Starter
medcop's Avatar
Thanks!
Enjoying life!
medcop is offline
