Why is my D60 pumping oil out the breather? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 06-29-2010, 01:06 PM Thread Starter
skeptic's Avatar
I have a currie d60 in the front. Whenever the hubs are locked it leaks oil out the breather hose. I'm guessing maybe when it was installed they put a little too much oil up front and that if I just drive around with the hubs locked for a while all the extra will eventually come out? WTF? Thanks.
2012 Rubicon Unlimited
skeptic is offline
post #2 of 11 Old 06-29-2010, 01:10 PM
frankie945's Avatar
I would pull the fill plug out and see if it was over filled. If so let it drain out till it stops and put the plug back in. It will make more of a mess letting it come out the breather.
frankie945 is offline
post #3 of 11 Old 06-29-2010, 03:17 PM
andrelopez99's Avatar
I'm new with currie! What I have read about this problem the past couple of days: I share this
- oil get too hot
- oil foams and spews
- too short vent hose
- o-ring or air leak in the differential
These were the main culprits
BTW what brand, weight of oil you running? What carrier you running..
andrelopez99 is offline
post #4 of 11 Old 06-29-2010, 04:14 PM Thread Starter
skeptic's Avatar
I'll try this tomorrow.
skeptic is offline
post #5 of 11 Old 06-29-2010, 04:17 PM Thread Starter
skeptic's Avatar
- oil get too hot
I'm not sure what brand/weight of oil was used as I didn't do the install. The shop is very good and has installed a lot of D60's so I'm sure whatever currie recommends is what they used.
Vent hose is plenty long. O-ring is a tougher guess/fix. I'm going to try pulling the drain plug first before I go that far. As far as overheating, not sure how to prevent that.
skeptic is offline
post #6 of 11 Old 06-29-2010, 04:31 PM
As fas as the heat, different forums ( desert racing, yota, etc) - have tried different weights with success.
Future note - another common issue is oil coming from the solenoid..R/T air leak in diff and/or o-ring.
post #7 of 11 Old 06-29-2010, 06:26 PM
Slippery's Avatar
There is no drain plug on the Currie rock Jock 60.
I had the same problem. At first, I let it find the level it liked and I kept it there, but it always got OVER FILLED.
I consulted with David at Currie. He went and looked at the drawings and came back with the front and rear fill levels and sent me these:
FRONT = 3" below the bottom of the fill hole.
REAR = 3 1/4" below the bottom of the fill hole.-
He also said to be sure and use the supplied vent hose, and not the factory ones.
He is on here so maybe he will confirm these findings again
Hope this helps.
I love my Rock Jocks and the service that John, David, and Travis have provided me.
Slippery is offline
post #8 of 11 Old 06-29-2010, 06:41 PM
Hope this helps.
Good to know..thanks slippery!
post #9 of 11 Old 06-29-2010, 06:46 PM
desert dog's Avatar
Mine did the same thing. It stopped doing it when the fluid got about 1.5-2" under the fill hole. I called Currie and was told that level is fine. No problems since.
desert dog is offline
post #10 of 11 Old 06-29-2010, 07:31 PM
Slippery's Avatar
For ARB's:
NON-sythetic gear oil - 85W-140 - hypoid racing oil
http://www.valvoline.co.za/Documenta...%2085W-140.pdf
Slippery is offline
post #11 of 11 Old 06-29-2010, 08:16 PM Thread Starter
skeptic's Avatar
Hope this helps.
sounds good. I meant fill plug I'll keep this in mind in the future when servicing my diffs.
Thanks guys.
skeptic is offline
