4" Rough Country lift with spring cups ? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 06-29-2010, 10:40 AM Thread Starter
i just installed a rough country 4" lift with 1.75" cups front and rear. will that be a problem? the exhaust is very close to the front drive shaft ( rubber boot). i put the cups in because of the front bumper with winch and rear tire carrier, has any one had a problem with that?
Seabeagle is offline
post #2 of 6 Old 06-29-2010, 10:43 AM
SONIC's Avatar
Cups?
I assume you mean spacers.
If so then it should be fine, but thats a lot of lift. You will need control arms and all the other stuff to go with that much lift.......
-Doc Holiday
SONIC is offline
post #3 of 6 Old 06-29-2010, 11:43 AM Thread Starter
yes, its a complete kit front/rear upper and lower control arms. on my TJ the bumper and winch lower the front down a inch or so.
post #4 of 6 Old 06-29-2010, 12:28 PM
planman's Avatar
You will need shocks, brake lines, driveshafts, steering correction, rear coil spring correction, swaybar links, and trackbar relocation sufficient for a 5.75" lift.
If you don't:
  • Your shocks will top out frequently offroad, and you may break the rear bar pins.
  • Your brake lines and ABS lines will be damaged/ripped out if they are too short.
  • Your front stock driveshaft boot will rip off on your exhaust and the joints will fail due to steep angles.
  • Your rear stock driveshaft joints will fail due to steep angles.
  • You will have steering issues with an approximate 6" lift without a steering correction kit.
  • Your rear coil springs will bow back and come into contact with your rear trackbar and/or frame side trackbar bracket.
  • Without rear spring retainers, your springs will become unseated from the lower perches, and you can lose a spring while offroading.
  • Your swaybar links will be too short, and if you have a Rubi, your front swaybar links will invert forward and wrap around your steering components when offroading.
  • Unless your trackbars and trackbar brackets have sufficient geometry to handle almost 6", your axles will be off center and you will have ESP issues and tire/wheel/swaybar/swaybar link/brakeline clearance issues.
  • Etc., etc.
Unless you are running 40s, why would you want a 6" lift anyway?
planman is offline
post #5 of 6 Old 06-29-2010, 12:30 PM
bubba2u's Avatar
is that the new x series lift with flex joints? how do you like it? did you try it with out the pucks. i was wondering how much lift you got with the bumper winch. if you have a 2 door you need a new drive shaft. hell with the pucks and 4" lift you probably need new shafts with a four door.
bubba2u is offline
post #6 of 6 Old 06-29-2010, 05:11 PM Thread Starter
its the "x" series kit complete with front track bar, SS brake lines, heim joints on the control arms, shocks etc.... i think i might need to get the rear spring clips( to hold the springs in). i had 2.5 spring cups on it before with 33" 11.5"s on a 9" wheel and i rubbed when i got the jeep crossed up on the trail. i'm getting my bumpers maded with a winch and tire carrier for the rear so the springs will drop from the weight. it did on my TJ. i got it aligned today and the esp light went off.
