What caster angle do you want? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 06-28-2010, 10:46 AM Thread Starter
Dynatrac's Avatar
We're researching doing a JK version front housing with an optional caster angle. We don't really want to make this a 'custom' so we need to know if one specific angle will fill the need for most of the market.
What do you think? What caster angle would you like to have?
Dynatrac is offline
post #2 of 7 Old 06-28-2010, 11:04 AM
muddpuppy01's Avatar
6* would be a good start point
muddpuppy01 is offline
post #3 of 7 Old 06-28-2010, 11:14 AM
I run 7*, but anything from 5.5* to 7.5* would work.
09rubicon is offline
post #4 of 7 Old 06-29-2010, 10:16 PM
Phil Howell's Avatar
With the coil buckets at 0 degrees, 6 degrees positive caster with pinion rotated 3 degrees up.
This way, the caster can be dialed to 7 degrees if needed and the driveline angle will still be good to go (fast).
Iacta alea est. (The die is cast)
--Julius Caesar, Divus Julius xxxii; spoken at the crossing of the Rubicon
Phil Howell is offline
post #5 of 7 Old 06-29-2010, 10:29 PM
I wish this would have been a option in Feb/March, I remember asking about it. This works though.
Alaska-HWY JK is offline
post #6 of 7 Old 07-01-2010, 09:10 AM
Impulse Off Road's Avatar
Here is the axle that Phil is talking about installed on his Jeep. Unless you have custom super long control arms, I would only recommend a 3 degree pinion angle. The upper arms had to be lengthened somewhere between 11/16-13/16". The Tera Flex Upper arms have a ton of adjustment and worked perfectly for this application.
Impulse Off Road is offline
post #7 of 7 Old 07-01-2010, 11:20 AM
SoK66's Avatar
The stock Rubi front D44 seems to have about 0 degrees pinion with 4.5 degrees caster. With a TF 4" lift my front driveshaft is at about 9 degrees, so splitting the difference at 4.5 degrees on the pinion and 5+ degrees caster should be in the pocket. OTOH, for shorter lifts maybe the 3 degree suggestion would work better, and would work for most other suspensions.
SoK66 is offline
