HID headlight help - JKowners.com : Jeep Wrangler JK Forum
post #1 of 26 Old 06-28-2010, 08:18 AM Thread Starter
rooster's Avatar
HID headlight help
Quick question...I put in some HID lights a couple of weeks ago and they have been working flawlessly.
Last week I took my Jeep in to the dealer because it wouldnt start. They replaced the PMC and the TIPM.
Now the HID lights blink on/off slowly and then they shut off all together and will not come on.
Any ideas?
rooster is offline
post #2 of 26 Old 06-28-2010, 08:21 AM
ADDICTION II build begins....
TXROCK's Avatar
Do you know if they reflashed the system after installing the new components?
U.S. Army
TXROCK is offline
post #3 of 26 Old 06-28-2010, 08:35 AM Thread Starter
rooster's Avatar
Yes they did. They had to because the PCM and TIPM were new/blank. I have since put my superchips program back in.
rooster is offline
post #4 of 26 Old 06-28-2010, 08:39 AM
TXROCK's Avatar
ahhh...gotcha. Stumps me....hold on....did you wire them into the factory fog light harness without using the light connectors? (meaning direct wire connections) I ask because that's what happened with my Delta Lights when I put them in using the factory fog light harness. I switched the wiring to the sPOD and haven't had any issues since.
U.S. Army
TXROCK is offline
post #5 of 26 Old 06-28-2010, 08:39 AM
do you have a capacitor/diode relay setup? Or some 'headlight fault cancel' deal?
post #6 of 26 Old 06-28-2010, 08:44 AM Thread Starter
rooster's Avatar
not fogs, headlights
yes I put in all the needed equipment. Its driving me crazy. Worked for a couple of weeks and now they dont...SUX
rooster is offline
post #7 of 26 Old 06-28-2010, 08:49 AM
TXROCK's Avatar
ok....
wondering if by any chance maybe the CAP (or Diode) blew in the capacitor/diode relay. with the blinking going on, sounds like an AC symptom on a DC circuit and then the completely off maybe a filled cap that is preventing any DC. Okay....really tired/loopy so I probably am not making sense cause I am confusing myself! HAHA Unfortunately still have 2 more "wake time" hours left before I can hop on the plane and sleep!
Good luck Rooster!
U.S. Army
TXROCK is offline
post #8 of 26 Old 06-28-2010, 09:07 AM
i say hook the HIDs directly up to the battery and see what you are dealing with. If they still act up, then your ballast or something just died coincidentally. imo.
post #9 of 26 Old 06-28-2010, 10:29 AM
SFCCotton's Avatar
Exact same thing happened to Dr. Dirty. He bought some error cancelling switches from ebay. I don't know if he installed them yet but PM him and I am sure he can help you out.
SFCCotton is offline
post #10 of 26 Old 06-28-2010, 10:49 AM Thread Starter
rooster's Avatar
yeah, Ive got those installed. Im going to pull it apart and see what happens.
rooster is offline
post #11 of 26 Old 06-28-2010, 03:02 PM
sPOD-guy's Avatar
Feedback: 12 reviews
Possible problem...
Rooster,
Are these HID lights that are replacing factory headlights? Or are they offroad lights that are HID and you are using the factory foglight switch to activate?
1) Do yourself a favor and just stay clear of any factory wires and DO NOT tap into any of them!
2) If they are a set of HID offroad lights, then go directly to the sPOD.
The ECU, TIPM is utilizing a CAN-Bus / MUX system which is programmed to recognize specific voltages or voltage change range. If it sees a different reading from those simple wires that you tapped into, it will try and adjust the voltage which in turn messes with your HID's!
STAY AWAY FROM CAN-Bus unless you are a highly skilled
-John the sPOD guy
switches jeeps panels jk-forum carling contura led switch windshield
sPOD-guy is offline
post #12 of 26 Old 06-28-2010, 03:19 PM Thread Starter
rooster's Avatar
Originally Posted by sPOD-guy View Post
Rooster,
No its the HID headlights conversion kit. With the cancellers and all that crap. They worked before they installed the new TIPM and PCM. I havent tapped into anything. I am going to try and power off the battery and if that works I guess I will run my headlights off the sPOD.
John - Im running out of room on the sPOD. When you going to make a lower dash panel sPOD??? I need more switches!
rooster is offline
post #13 of 26 Old 06-28-2010, 05:44 PM
sPOD-guy's Avatar
If they reflashed the TIPM system, you will continue to have problems. It is trying to regulate the power being supplied to the HID's.
Well, if you can find a second spot for the Source, then this little sPOD will clamp onto your roll-bar and you will have another six circuits to play with!
[IMG][/IMG]
-John the sPOD guy
sPOD-guy is offline
post #14 of 26 Old 06-29-2010, 04:43 AM Thread Starter
rooster's Avatar
[IMG][/IMG]
John, I dont see it listed on your website. What are the details? How much is it?
rooster is offline
post #15 of 26 Old 06-29-2010, 06:07 AM
sPOD-guy's Avatar
E-mail me....we havenít finished the photo shoots yet on the mini, but they are available.
e-mail me @ [email protected]
Does your roll bar have padding ?
-John the sPOD guy
sPOD-guy is offline
post #16 of 26 Old 06-29-2010, 07:40 AM
Dr.Dirty's Avatar
Feedback: 21 reviews
Hey rooster the error cancelers i bought did not work, mine worked fine untill the dealer reflashed my tipm as well.....
www.jeepasylum.com
Dr.Dirty is offline
post #17 of 26 Old 06-29-2010, 06:40 PM Thread Starter
rooster's Avatar
Scott what did you do to fix the problem then? New cancellers? Its driving me crazy. Joker and I worked on it over the phone today and moved everything around, tried different combinations and it was the same results every time. So I put my PIAA bulbs back in until I can get it resolved.
rooster is offline
post #18 of 26 Old 06-29-2010, 06:46 PM Thread Starter
rooster's Avatar
email sent...no padding
rooster is offline
post #19 of 26 Old 06-29-2010, 08:15 PM
curbsjeep's Avatar
Might be a dumb question, but have you checked all the connections. I had that happen on a different car, found out the connection at the bulb was slightly loose.
curbsjeep is offline
post #20 of 26 Old 06-29-2010, 08:20 PM
so did you hook it directly to the battery yet?
post #21 of 26 Old 06-30-2010, 08:07 AM Thread Starter
rooster's Avatar
Yes same thing. Im thinking its either bad cancellers or something with the reflash of the TIPM has caused them to stop working.
Joker and I worked on it over the phone. I took the HID off line and turn the lights on and it didnt throw a code to let me know they werent lighting up. So Im thinking the reflash did me in.
I sent VVME an email and they are working on sending me replacement parts.
rooster is offline
post #22 of 26 Old 06-30-2010, 08:10 AM
Dr.Dirty's Avatar
Im betting its your TIPM like mine is, I have pluged mine into another JK and it worked fine and the also work fine in my YJ. Mine were working fine for months till the TIPMM died
www.jeepasylum.com
Dr.Dirty is offline
post #23 of 26 Old 06-30-2010, 09:21 AM Thread Starter
rooster's Avatar
So you had to take yours out? That sux! What could they have done to our TIPM's to keep them from not working if they worked before? Thats BS but ofcourse you cant go back to the dealer and make them fix it.
Guess if they wont work I will be putting them in the tow rig or the wifes new Camaro
rooster is offline
post #24 of 26 Old 06-30-2010, 10:00 AM
That sucks, I had my TIPM replaced and didnt have a problem. I don't have cancelers, I have a relay with a capacitor and diode.
post #25 of 26 Old 06-30-2010, 10:42 AM Thread Starter
rooster's Avatar
Is yours wired to a switch or off the battery? Do you mind PM'ing me your set up or if you have any pics of how your capacitor/diode works. Thanks!
rooster is offline
