Poly Pro Steering Stab bracket with Teraflex SS? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 06-27-2010, 09:31 AM Thread Starter
Cedo Nulli's Avatar
I busted my stock steering stab a while back, bought a Teraflex steering stab and while it's great, it's bigger than stock and I need to relocate it to get it above the tie rod.
Looking at this bracket from Poly Pro:
http://www.polyperformance.com/shop/...t-p-18361.html
Anyone running these two together? Any issues? Club has a run coming up next weekend and I'm trying to get a fix so I can get it out on the trail.
Cedo Nulli is offline
post #2 of 3 Old 06-28-2010, 06:28 AM Thread Starter
Cedo Nulli's Avatar
Anybody?
post #3 of 3 Old 06-28-2010, 06:48 AM
SoK66's Avatar
Probably not a bad addition to your rig. If you're running a Poly, AEV, etc, track bar mount you can simply bolt the stabilizer to the track bar bracket, then loosen and rotate the tie rod bracket 90 degrees so it's on top of the tie rod. Be sure to check for clearance between the dampener body and the bracket, shim it out a bit if needed.
SoK66 is offline
