Rerouting exhaust (eliminating cross over pipe) - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 06-25-2010, 09:00 AM Thread Starter
Ogie's Avatar
Since my engine/trans skid plate has been well used and is now bowed up a bit, it hits the exhaust cross-over pipe that runs beneath the trans; which causes annoying rattles. I'm looking for ideas on how to reroute the exhaust to eliminate that, but I would like to keep my muffler (aftermarket but installed in same place as stock); so, I would probably need to run another cross-over pipe somewhere else. Question is where and how? Open to other ideas, too. Chime in and thanks in advance.
Vidi, vici, veni
2008 Jeep JK Wrangler Rubicon Unlimited
Ogie is offline
post #2 of 8 Old 06-25-2010, 05:47 PM Thread Starter
Ogie's Avatar
Anybody? Anybody? Bueller? Bueller?
Vidi, vici, veni
Ogie is offline
post #3 of 8 Old 06-25-2010, 06:18 PM
daspes's Avatar
Wouldn't it be easier to replace the skidplate?
daspes is offline
post #4 of 8 Old 06-25-2010, 06:30 PM Thread Starter
Ogie's Avatar
sure if I had another $350 bucks burning a hole in my pocket. And then when that one gets bowed I can spend that much again? No thanks. I'm looking for a permanent solution.
Vidi, vici, veni
Ogie is offline
post #5 of 8 Old 06-25-2010, 06:32 PM
daspes's Avatar
Which plate are you running?
daspes is offline
post #6 of 8 Old 06-25-2010, 06:35 PM Thread Starter
Ogie's Avatar
Kilby. but when you wheel out here on big rocks/boulders, it doesn't really matter whose you're running - it's going to eventually get bowed.
Vidi, vici, veni
Ogie is offline
post #7 of 8 Old 06-25-2010, 06:46 PM
daspes's Avatar
I used to be stationed out there, familiar with the area.
God, I miss Big Bear...
Not sure how the 3.8 would react to a pair of straight pipes... Pretty sure that with out an X/H pipe somewhere the engine will throw a fit. Can't think of any place other than factory where you can fit a collector though. Maybe an exhaust shop can pull the pipe and put it on the mandrel and tweak the bends to raise is up a bit away from the skid.
Another idea is to pull the skid and have it pressed back into a flat(ish) shape again, weld some reinforcement the top, and maybe add some HDPE to the underside to help distribute the weight when you do come down on the skid and help you slide over instead of denting.
daspes is offline
post #8 of 8 Old 06-25-2010, 06:58 PM Thread Starter
Ogie's Avatar
I
That's what I was thinking but I don't know who could press it back to shape. It would need one hell of a press. Even if I bought a new one and then I tried to reinforce it, I'm afraid the support rods (for reinforcement) would then hit the pipe.
I might go to my local muffler shop and see what they can come up with - they do a lot of custom stuff; so they might have an idea.
Vidi, vici, veni
Ogie is offline
