What Exactly is that loud "WHACK" when I shift?? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 06-21-2010, 07:53 PM Thread Starter
upalms's Avatar
Question What Exactly is that loud "WHACK" when I shift??
I've heard people say their JK does it, some since new, but what exactly is it that makes the loud WHACK when you shift? I've been all over this today, retorking the control arms, track bars, changed the tranny fluid, still shifts like crap, and stll makes that Friggin WHACK when you shift, usually in the lower gears, almost sounds like a spent chain in a transfer case, close as I can describe it.
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
Synergy Front Suspension
Artec Front JK Armor
5:13's
Tom Woods Drive Shafts
Hi-Lift & Much More
2000 TJ
6" lift
37 TOYO MT's on Worx Rims
$hitty Built bumpers
Air Raid
Corbeau Baja RS seats
upalms is offline
post #2 of 16 Old 06-21-2010, 07:57 PM
Driveline slop really. Slop in the driveshafts/differential ring/pinion, maybe t-case related like you mentioned. However mine doesn't really do that unless I release the clutch too quickly or am in Rubi-low. Seems like you have issues with yours that I've really yet to experience.
Mine shifts very smooth and quiet if I am remotely trying to drive it smooth.
post #3 of 16 Old 06-21-2010, 08:01 PM
guinness's Avatar
Nevermind.
I thought it said when I sh!t.
Rest In Peace Guinness. You will never be forgotten. My brother and my best friend
guinness is offline
post #4 of 16 Old 06-21-2010, 08:07 PM
RubiRed Unlimited's Avatar
Not sure if its the same, but with everything being "unserviceable" under there, Im having a similar issue, but mine is an unlimited rubicon with an automatic. I can't narrow it down yet, first thought was control arm sticking when the weight shifted when I turn and accellerate from a stop. Now Im thinking something with brakes? Can't narrow it down yet. 40K miles and it seems to only to happen when Im transferring from brake to accelorator and turning at the same time...could be anything if it's even the same thing!
RubiRed Unlimited
ARB bumpers
Superwinch 9.0i
3.5" AEV premium lift
35" KM2s, OR-Fab tire carrier
Viair on board air
RubiRed Unlimited is offline
post #5 of 16 Old 06-22-2010, 05:57 AM Thread Starter
upalms's Avatar
RubiRed Unlimited, if you're thinking it's something loose, which sounds more like your issue, try getting under it and have someone rock it back and forth in park, or even try with the E brake on in 4WL, and watch all the mounting points first, control arems, track bars, sways, you may be able to isolate it. Mine I believe is more driveline related.
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
5:13's
Hi-Lift & Much More
2000 TJ
6" lift
Air Raid
upalms is offline
post #6 of 16 Old 06-23-2010, 05:54 AM
I get a heavy clunk from the front right hand side. I've been told its the axle touching the side of the axle tube. It makes sense as everything else is tight and serviceable.
ex: RHD JK 2dr CRD auto
CRDTom is offline
post #7 of 16 Old 06-23-2010, 08:29 AM Thread Starter
upalms's Avatar
this is more of a Whack or a Clack sound, it does sound like slop, just don't know with 20k on it why anything should be sloppy
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
5:13's
Hi-Lift & Much More
2000 TJ
6" lift
Air Raid
upalms is offline
post #8 of 16 Old 06-23-2010, 08:33 AM
Have you turned a driveshaft by hand, ever, and felt the slop? Slop in the t-case and ring and pinion backlash are necessary. There is a good amount there, and if you're a little jittery on the clutch can potentially make noise if the vehicle slows enough between shifts then whacks into the next gear.
post #9 of 16 Old 06-23-2010, 08:54 AM
Jason @ Warrior's Avatar
I've driven about 7 JK's now and had 4 that the shop has owned...no loud "whack" noises in any of them...I definitely wouldn't be writing it off as nothing. Usually that kind of stuff is loose suspension or bad bushings somewhere.
Jason @ Warrior is offline
post #10 of 16 Old 06-23-2010, 09:17 AM
J. Kickerman's Avatar
That loud whack is your palm hitting your forehead as you realize you should have gotten the auto.
2009 JK Rubicon Unlimited. Rock Hard skids, Skidrow Control Arm Skids, Shrockworks bumpers. Pro Comp 2" Puck Lift.
J. Kickerman is offline
post #11 of 16 Old 06-23-2010, 09:26 AM
Totally different vehicle, but I had a 95 escort that did that, but only second to third. (maybe first to second, I forget)
It was a broken transmission mount.
Check those, apparently the escort's broke because I was learning to drive on it, and had a bat habit of accidentally powershifting which broke the mount.
Fnord5 is offline
post #12 of 16 Old 06-23-2010, 10:28 AM
bodybrdng's Avatar
......However mine doesn't really do that unless I release the clutch too quickly or am in Rubi-low. .....
Exact same thing here.
bodybrdng is offline
post #13 of 16 Old 06-23-2010, 11:05 AM
riverzendz's Avatar
It's driveline slop, lots of manuals will do it, and has nothing to do with mileage.
Rarely do I notice it unless I'm in low range.
riverzendz is offline
post #14 of 16 Old 06-23-2010, 11:06 AM
riverzendz's Avatar
By "auto" you mean those things that overheat and catch on fire?
post #15 of 16 Old 06-23-2010, 11:25 AM
Exactly! As opposed to the self destructing clutch plates, throw it out bearings you know, crap.
post #16 of 16 Old 06-23-2010, 11:44 AM Thread Starter
upalms's Avatar
I'm not really an Auto person, just me, I am shifting somewhat gingerly because the way the trany is behaving, shifting rough, have to push it in gear, the lift only has 3,000 on it, and I went over every nut and bolt the other night, all looks good. I will go over the mounts though and see if I notice anything there.
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
5:13's
Hi-Lift & Much More
2000 TJ
6" lift
Air Raid
upalms is offline
