Wheels - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 04-02-2007, 12:52 PM Thread Starter
Mikey's Rubi's Avatar
Wheels
Will 15's work on the JK Rubicon? I would like to fit 15x8 or 15x10's under there for the upcoming lift. Speaking of that...I will have the stock rims and tires for sale (Rubicon Moab wheels and 32" BFG Mt's) so if anyone is interested let me know.
Mikey's Rubi is offline
post #2 of 10 Old 04-02-2007, 02:44 PM
JK Wheeler's Avatar
I do think they will work
JK Wheeler is offline
post #3 of 10 Old 04-02-2007, 11:07 PM
Living Still's Avatar
There are some 15s that will work, but not all of them will fit. As far as I know 15" steelies have been working out for people. Just make sure to test fit to see if they work out. If not send those puppies back. It also depends on how much clearance between the caliper and the inner wheel you are comfortable with. It can get pretty tight in there.
-Living Still
Living Still is offline
post #4 of 10 Old 04-03-2007, 07:42 AM Thread Starter
That is what I am afraid of...I think I want a little room so a 16 may be the way to go.
post #5 of 10 Old 04-03-2007, 08:11 AM
Denis's Avatar
Send a message via AIM to Denis Send a message via Yahoo to Denis
Just order one wheel to try, if it doesn't fit, it's easy to return just one.
Denis is offline
post #6 of 10 Old 04-11-2013, 07:32 AM
greenenvey's Avatar
What year is your jeep? Is it grey?
Sent from my DROID RAZR using Tapatalk 2
2010 rubicon. 3.5 rk lift. 37,s. 6.2 Ls3.
greenenvey is offline
post #7 of 10 Old 04-11-2013, 09:20 AM
Victim Of Pain's Avatar
Just grind the caliper down and don't look back. Saves a lot on the tires too with 15" wheels. My fronts rubbed so I took the grinder wheel to the caliper and took off about an eighth of an inch, no problems at all.
Victim Of Pain is offline
post #8 of 10 Old 04-11-2013, 09:29 AM
A JKO DICK
ASSFROW's Avatar
It's not just the caliper. You are limiting your choices for tie rods when the crappy stock one shits the bed. Do 17's less rubber to balance, more tire choices.
ASSFROW is offline
post #10 of 10 Old 04-11-2013, 10:24 AM
JKO Dickhead
Asmmns's Avatar
Both sets of my aluminim 15's fit with no rubbing -
Pro-Comps and Racelines
And they work with the RK heavy duty tie rod with Moog Ends
__________________
CURE SMA !
Asmmns is offline
