Extra Fuel Tank - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 08-29-2015, 10:02 PM Thread Starter
Extra Fuel Tank
Has anyone installed a custom baffled 20 plus gallon fuel tank in the rear of the JK?
Not talking about Genrght. I am already running the Genright fuel tank and have taken out the factory fuel tank on a 4 door JK. The suspension, coilovers and Bypass setup forced me not using factory tank.
JK07 is offline
post #2 of 4 Old 08-31-2015, 11:24 AM
I did. But why would you want to replace the Genright? If you have a CAD drawing of what you want, Boyd fuel cells is the way to go and that is who I used. http://www.boydwelding.com/
I had what would be considered a fairly complex design and I paid around $650 shipped and it is every bit the quality of Genright.
They had me send in the sending unit and rollover valves (I used YJ valves). Then they build the tank so everything fits. I modified the sending unit to be about 5" taller as well. I'm running a double triangulated rear and had to move everything around, but it was an easy project. The fuel fill is still in the same location though.
Invest2m4 is offline
post #3 of 4 Old 08-31-2015, 01:30 PM
Here are a few pics. I will have to grab some of it in the Jeep.
EVAP
$55 pump ring since the $200 Genright ring is a ripoff.
post #4 of 4 Old 08-31-2015, 04:56 PM Thread Starter
Thanks look like a very well built tank.
I am not replacing the genright fuel. I want to add extra auxilary fuel tank for long distances 20 gallon plus custom built probably gravity feed at the rear. Its a JKU.
Pic for attention
JK07 is offline
