advice on synergy high steer - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 08-24-2015, 09:08 PM Thread Starter
has anyone installed it and what are your thoughts on currie, rock krawler, or teraflex kit?
jeepjkmango2011 is offline
post #2 of 7 Old 08-24-2015, 09:19 PM
I have the synergy drag link flip kit (i believe thats what your asking about.) Its a pretty easy install. You do need to weld it but it has bolts so you can install and drive to a welder if you lack that skill.
2011 Jk 2 door 6 speed. 5.13 gears, 1350 driveshafts, cooper sst+ 35s, warn 9.5, various armor, 1/4 pounder bumper, 12 inch King coil overs, CB, still running the dana 30 sleeved and gusseted up front. Someday wanna go with 1 ton axels but for now I love my JK.
ChicagoJK2011 is offline
post #3 of 7 Old 08-24-2015, 09:36 PM Thread Starter
i didn't think you needed to weld anything ?
post #4 of 7 Old 08-24-2015, 09:44 PM Thread Starter
do you need to weld them
post #5 of 7 Old 08-24-2015, 09:47 PM Thread Starter
http://www.quadratec.com/Assets/Installation/92032.pdf
im not understanding the welding part it looks like its held on by u bolts but my friend is a welder not a problem I'm just wondering what needs to be welded
post #6 of 7 Old 08-24-2015, 10:06 PM
sorry my bad. wasn't trying to confuse you. it doesn't say to weld it on
When putting mine on it was the same time as the coil overs install so i probably didn't even read the directions. The joints have held up. Its just mainly get the drag link out, drill out the top of the knuckle, install the bracket and your done.
post #7 of 7 Old 08-29-2015, 09:53 AM
JoeVacs's Avatar
I've had mine installed for 4 years now and had no trouble. You do need to re-tighten everything a couple of times for the first couple of months.
2010JKU rubicon, 4'' lift, Currie arms, Synergy ball joints, gussets, and sleeves,Currie high steer and track bar, 40" Procomp MT2 tires, Pro Comp wheels, 5:13 gears, Bilstein 5100 shocks, Tom Woods shaft, Warn Powerplant front, Warn VR8000 rear. Masterpull synthetic lines
JoeVacs is offline
