Noob questions about suspension - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 08-21-2015, 09:17 PM Thread Starter
Hello guys,
I have a 15' JKU with the FOX/Mopar stage I 2" lift that comes with:
Coil Springs
Brake Line Brackets
Cam Bolts
Rear Track Bar Bracket
Shocks
Sway Bar Links
Bump Stops
Front Driveshaft
I have a steal bumper with hoop and a winch and would like to level and then add an inch (ie. 1 3/4" or whatever it takes up front and 1" in rear).
I've been looking at spacers and just replacing the coils. I like the idea behind metal cloak's true dual rate springs but am wondering if I will really see the difference between them and my correct rate 2" springs under spacers.
It seems like the spacers would act just like the compressed road coils and still add tension at full flex (not having coil issues now).
since the metal cloak coils fully compress on flat ground, would they allow any more upward travel than my coils under spacers?
Is there anything I'm not seeing here? (besides the "don't use spacers because, well because" arguments)
My fox 2.0 shocks are good to 3.5" of lift and I have all of the supporting mods for 3.5" minus adjustable trackbar. I don't want to lose on road stability but do want more off road clearance as I stuff the chit out of my 35's.
I do plan on flipping my drag link, track bar, steering stabilizer and going adjustable in the future. Is there anything else I would need to do for reliability and performance?
Anyone know of a good bolt on high steer kit that would take care of all that?
Thank you in advance for your time.
15' White JKU- 2" lift, 35" tires, Gibson MM exhaust, etc.
Fedfireman is offline
post #2 of 3 Old 08-22-2015, 12:45 AM
Feedback: 10 reviews
Your kind of answering your own questions really. Sounds like you understand the basics as far as the coils and spacers.
As far as the Mopar 2in lift. I sell them and install them. You should not change anything. It was engineered the way it is for a reason, so it will not void your warranty with Chrysler. The 2in Jeep Performance Parts lift raises the front end 4in and the rear 2in. It was made to sit level with a bumper and winch.
If you feel you want High steer the best thing would be the AEV Highsteer kit. I doubt a dealer would even notice it, they look very OEM.
My advice is to figure out what kind of wheeling your going to do and make a plan. Mud, Rocks, Overlanding, Mostly street, Baja, or etc...
Heres a couple we did at the shop with the same lift you have. I rides like stock, for 95% of people its perfect to run 35in and stock flares or 37in with flat flares.
Stock with 2in Jeep lift only. This jeep has been all over the country wheeling hard in stock form before the lift. Check out the gnarly rock rash. Your much better off investing in a good skid plate like this RockHard version, over spacers or different springs.
This is RhinoLiner on the entire JK and 10A hood and Genright fenders and 35in rubber. This Jeep owner isn't as hard offroad but he has a RIPP supercharger to make it more interesting on the street...
Stangbuster is offline
post #3 of 3 Old 08-27-2015, 08:59 PM Thread Starter
I feel like those jeeps are more leveled than mine is. I measured height to two fixed spots on mine and my friend's bone stock JKU and it was 4" on the money front and back. 2" of lift and 2" of tire.
