6l80e Alignment Issue w/Shift Gate - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 08-14-2015, 10:46 PM Thread Starter
Has anyone experienced an issue with the 6l80 shifter being slightly off when swapped into a 2011+ JKU? One I'm looking at buying has the MoTech kit used for a 6.2/6l80 swap and the shifter is off about an inch from what it was stock. Not a huge issue but more of an annoyance. Any insight would be appreciated. Thanks.
rayzjeep is offline
post #2 of 10 Old 08-16-2015, 08:24 AM
jss
jss's Avatar
The shifter from 2007-2011 work out well, the 2012-2015 shifter i think does not work out has well. But it does work, it is off a little.
I have a 2008 Jeep JK and i have a 2011 shifter and it works great, i had a 2012 shifter and i did not like it has much. I like the Tap Shift on the shifter handle, just my opinion.
["jeep speed shop The GuineaPig Build"]
VVT Truck Hemi Conversions
The ONLY CARB LEGAL JEEP ENGINE CONVERSION
7911 Redwood Dr, Cotati, Ca. 94931
707-338-3154
jss is offline
post #3 of 10 Old 08-17-2015, 06:43 AM
0lllllll0 RPMEXTREME's Avatar
It should match up except for maybe first gear.
The motech shifter bracket is adjustable and you should be able to get all the ranges to match up except it may be difficult to pull it down all the way to manual 1st gear.
post #4 of 10 Old 08-18-2015, 05:51 AM Thread Starter
Shifter is from a 2011 as the swap was done on a 2011 JKU Rubicon. It's more something you can feel than see visually, that the shifter goes past where it would normally when shifting down from Park. The shop tried to adjust it several times as it's a MoTech kit but this was as good as they could get it.
Does it matter that it doesn't have the cruise kit add on?
rayzjeep is offline
post #5 of 10 Old 08-18-2015, 06:59 AM
cruise wouldn't matter. you should be able to get it dead on if it was installed correctly.
post #6 of 10 Old 08-18-2015, 08:49 AM Thread Starter
The shop said that the additional length of the 6l80 when compared to the jeep transmission was the reason behind the shifter feeling slightly off. They tried to adjust it several times but it's still not spot on. Sounds like something may have been installed incorrectly?
rayzjeep is offline
post #7 of 10 Old 08-18-2015, 11:02 AM
The motech shifter bracket should have came with a new shifter arm to bolt to the trans. I think its slightly shorter or longer and helps make it match up.
post #8 of 10 Old 08-18-2015, 02:04 PM Thread Starter
Yeah they said they installed the shifter arm...but when they tried to adjust it where it was supposed to be, they couldn't get it to shift into Park.
rayzjeep is offline
post #9 of 10 Old 08-18-2015, 04:54 PM
Have you tried calling Motec................................
CT Performance, Inc is offline
post #10 of 10 Old 08-18-2015, 09:46 PM Thread Starter
Not yet…I probably should though….I just didn't want to be a bother.
rayzjeep is offline
