removing nuterts from the body - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 08-13-2015, 11:30 AM Thread Starter
j-rod17's Avatar
Anyone tell me how to go about removing nuterts in the body of the JK?
I am about to make some changes to mine that will require removing 16 nutserts.
help is much appreciated!
2008 JKU: continual work in progress
j-rod17 is offline
post #2 of 13 Old 08-13-2015, 12:31 PM
Cut the outside lip and punch em in...
family4x4 is offline
post #3 of 13 Old 08-13-2015, 01:00 PM
Rossi46's Avatar
Could you drill them out?
Rossi46 is offline
post #4 of 13 Old 08-13-2015, 06:37 PM
bigworm36's Avatar
They may just spin
bigworm36 is offline
post #5 of 13 Old 08-13-2015, 07:09 PM
Thisguyhasadd42's Avatar
You just gonna cover the holes with new armor? If so, I'd just leave them. I see them just spinning if you try to drill them out like bigworm said.
2010 Mango 2dr 6spd Rubicon
Thisguyhasadd42 is offline
post #6 of 13 Old 08-13-2015, 10:23 PM Thread Starter
j-rod17's Avatar
Yes I plan to put new skins over them
j-rod17 is offline
post #7 of 13 Old 08-14-2015, 04:42 AM
kjeeper10's Avatar
What about using a step drill? Slowly drill away the face until you're able to punch it through. I can't doing it without the threaded section being lost behind the panel.
kjeeper10 is offline
post #8 of 13 Old 08-14-2015, 05:09 AM
Just cover and forget
post #9 of 13 Old 08-14-2015, 08:18 AM
Can't you resuse the holes with the new armor? That is what I did.
When the nutsert crushes the diameter increases significantly, especially on the inside. I had to remove one and found a 3/4" hole saw was the exact size. I personally wouldn't go to town on a bunch of them that way.
You could cut the lip off and squeeze as noted above, but you would only be able to push it in and not pull it out. Not sure having a bunch of nutserts in the body is ideal.
Invest2m4 is offline
post #10 of 13 Old 08-14-2015, 08:23 AM Thread Starter
j-rod17's Avatar
I'm not sure how they will line up yet, if at all. I'm sure the EVO corners and the Smitty ones are going to be way different.
The EVO already can tell take twice as many to mount as the Smitty and I'm sure my luck none will line up lol
j-rod17 is offline
post #11 of 13 Old 08-14-2015, 08:26 AM
Did you already get them? If not, ask if they can send without the holes drilled and then drill your own. Use the current armor as a template.
post #12 of 13 Old 08-14-2015, 08:31 AM Thread Starter
j-rod17's Avatar
they are already in my buddies garage. I am getting a deal on them so I will make them work.
I have to change my rock rails in order to properly cage it. to change the rock rails like I want I have to change my corners. LOL. damn domino effect.
I will find a way. Just didnt really know of there was a good way for removal besides letting them lay inside.
j-rod17 is offline
post #13 of 13 Old 08-14-2015, 08:32 AM
Honestly, just leave them in. You won't see them. The body panel is stronger with them in anyway.
