tom woods driveshaft front pinion angle - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 08-10-2015, 01:33 PM Thread Starter
Cool tom woods driveshaft front pinion angle
i have a 4 inch rc lift on a 2 door, what should my front pinion angle be at does anyone have a 4 inch lift with after market driveshaft how much should i pitch the front? does anyone have the measurements of their threads on the uppers?
jeepjkmango2011 is offline
post #2 of 7 Old 08-10-2015, 01:42 PM
kjeeper10's Avatar
You have to balance pinion AND caster. I would start around 4.5 (+ 1.5 at the pinion. If you feel any vibes dial in more pinion.
kjeeper10 is offline
post #3 of 7 Old 08-10-2015, 02:00 PM Thread Starter
i don't have vibe my rear is right on, but with the front i do have a shimmy dw steering could it be i pitched the front too much
post #4 of 7 Old 08-10-2015, 02:22 PM
kjeeper10's Avatar
Sounds like a diff problem.
post #5 of 7 Old 08-10-2015, 02:35 PM
kjeeper10's Avatar
How are you ball joints ?
post #6 of 7 Old 08-10-2015, 10:49 PM
Remove the front shaft just to take it out of the equation, then fix the shimmy/wobble. You could probably just do an internet search for Planman's writeup and follow the steps.
Once the steering is dialed in, reinstall the shaft and see how much caster you can get away with.
GreenJK is offline
post #7 of 7 Old 08-11-2015, 07:10 AM
on 4" of lift you front pinion angle will be terrible. Like others have said it is a balance of caster and vibrations cause by the poor angle.
