steering components synergy or teraflex - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 08-10-2015, 10:09 AM Thread Starter
Red face steering components synergy or teraflex
i have a 2011 jk 2 door with 4 inch rc lift and my steering is just overall weak i wanted to do a drag link flip with new track bar and tie rod, but was unsure what i needed. i see a lot of people with the synergy set up with the relocation brackets and i see people with the teraflex frame brace. also will i need new swayer links i have aftermarket but not adjustable and will i need to get a bracket to raise the track bar in the rear. the first two pictures are mine and the 2nd two are random pictures, please give me your thoughts on what i should upgrade to and what i will need. This is the last thing i have new driveshafts(tom woods) and all new control arms.http://i1339.photobucket.com/albums/...psty9h8gwy.png
http://i1339.photobucket.com/albums/...psmvm1ioxz.png
http://i1339.photobucket.com/albums/...psh3wqwdeu.jpg
http://i1339.photobucket.com/albums/...psral8xphc.png
jeepjkmango2011 is offline
post #2 of 11 Old 08-10-2015, 10:29 AM
Ive been running the Synergy high steer kit for a long time...it just flat out works....and works incredibly well. One of the best set ups imo for running ram assist since the draglink gives you a lot of real estate to work with. Whatever route you go with, make sure you get the synergy bracket to raise up your track bar mount to keep things lined up. Get some adjustable sway links front/rear, and either the Synergy or Tera rear trackbar bracket and you will be good to go. The new Teraflex high steer system looks to be of high quality as well.
Ridgeline Off Road is offline
post #3 of 11 Old 08-10-2015, 12:20 PM
BigPrince's Avatar
I highly recommend synergy.
BigPrince is offline
post #4 of 11 Old 08-10-2015, 12:33 PM
kjeeper10's Avatar
both Bring the drag link to the top of the knuckle. The difference, Synergy raises the track bar. TF Lowers the track bar.
Imo raising the track bar is the better way to go.
kjeeper10 is offline
post #5 of 11 Old 08-10-2015, 12:48 PM
j-rod17's Avatar
Synergy
2008 JKU: continual work in progress
j-rod17 is offline
post #6 of 11 Old 08-10-2015, 01:15 PM Thread Starter
do you mind sending me a picture of your set up and what all do i need to do it. right now i have a drop pitman arm do i need to put the stock pitman arm back on and do i have to raise the rear track bar as well?
post #7 of 11 Old 08-10-2015, 01:22 PM Thread Starter
what adjustable sway links do you recommend i have aftermarket ones do i need adjustable?
post #8 of 11 Old 08-10-2015, 01:26 PM
A JKO DICK
ASSFROW's Avatar
I vote Synergy...................Deja Vu?
ASSFROW is offline
post #9 of 11 Old 08-10-2015, 01:44 PM
kjeeper10's Avatar
Yes .. Get rid of the DPA.Name:  ImageUploadedByAutoGuide1439235844.611381.jpg
Only difference here is i have a Artec Bracket. (Replaced Synergy's when the truss was added)
post #10 of 11 Old 08-10-2015, 02:02 PM Thread Starter
post #11 of 11 Old 08-10-2015, 03:18 PM
Teraflex draglink flip, with synergy tie rod and trackbar.
had a teraflex trackbar but when i raised my trackbar bracket, the bow on the TF trackbar was too big and my pitman arm was making contact with it...so i went with a synergy TB
MISHIMOTO IS JUNK
chknkatsu is offline
